2020 Indian Scout Sixty [Model Overview] Copy
The 2020 Indian Scouty Sixty is No Pushover​
The American-made 2020 Indian Motorcycles Scout Sixty is the lowest power of the Indian Scout models, but that doesn’t mean it’s a pushover by any means, Powered by a 999cc liquid cooled 60 degree v-twin, it produces 78 HP and 65 lbs-ft of torque, transmitted through a wet clutch 5 speed.
In terms of styling, the Scout Sixty is a bike that borrows the best elements from its brothers in the 2020 model range. A blacked out engine style from the Scout Bobber, as well as a saddleback bobber seat. The standard handlebars from the base Scout, the fairings from the Scout 100th Anniversary. Put together, it makes for an attractive and purposeful sports cruiser that is at home anywhere.
As well, the Scout Sixty is aimed at the public as an introductory model. Indian specifically want to show off the style, the customizability, the sound, and the power of their bikes. As for customization, the fact that the accessories list takes up a few pages of the brochure should be telling.
The 2020 Indian Scout Sixty starts at $8,999 USD / $10,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Scout Sixty in one place.
Motorcycle Overview​
  • Price: $8,999 USD / $10,999 CAD
    • Cruise control
    • ABS
    • Low Seat Height
Main Specs​
  • Engine type: 999cc liquid cooled 60 degree v-twin
  • Horsepower: 78 hp
  • Torque: 65 lbs-ft
  • Wet weight: 245 kg / 540 lbs
  • Seat height: 65 cm / 25.6 in
Competitors​
2020 Indian Scout Sixty Specifications​
ENGINE
Engine999cc liquid cooled 60 degree v-twin
Engine Power78 Hp
Bore x Stroke3.661 in x 2.898 in (93 mm x 73.6 mm)
Compression Ratio11:1
Fuel SystemClosed loop fuel injection / 54 mm bore
Lubrication
DRIVETRAIN
ClutchWet, Multi-Plate
Transmission2.357 : 1
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearDual Shocks
Brakes FrontSingle / 298 mm Rotor / 2 Piston Caliper
Brakes RearSingle / 298 mm Rotor / 1 Piston Caliper
Tires FrontKenda K673F 130/90-16 72H
Tires RearKenda K673 150/80-16 71H
Fuel Tank Capacity3.3 gal (12.5 L)
ColorThunder Black, Burgundy Metallic, Pearl White/Titanium Metallic
ELECTRICAL
Ignition
HeadlightHeadlight
Tail LightTaillight
DIMENSIONS
Overall Length91.4 in (2,321 mm)
Overall Width36.1 in (916 mm)
Overall Height42 in (1,068 mm)
Wheelbase62 in (157.6 cm)
Ground Clearance5.7 in (14.5 cm)
Seat Height25.6 in (649 mm)
Wet Weight540 lbs / 560 lbs (245 kg / 254 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2020 Indian Scout Sixty Features​
OPEN INVITATION TO THE OPEN ROAD
The lightweight, cast aluminum frame, and low seat make for an expertly balanced bike that’s easy to handle at all speeds.
MODERN, LIQUID-COOLED V-TWIN ENGINE
Powered by a blacked-out, liquid-cooled, 60-cubic-inch, 78-horsepower V-Twin engine for a thrilling ride.
ELEVATE YOUR RIDE
Put the finishing touches on your ride with authentic Indian Motorcycle accessories.
AN ICON. REMASTERED.
The engine, headlights, fenders, and wheels were inspired by the original Scout of the 1920s.
BLACK-OUT STYLING
The modern 78-horsepower V-Twin comes in one color and one color only: black.
COMFORT THAT GOES FURTHER
As comfortable as it is stylish.
ENGINEERING IS EVERYTHING
Electronic fuel injection and liquid cooling are just some of the advanced engineering features giving the Scout Sixty unmistakable power every time you fire up the engine.
ABS STANDARD
Superior stopping power with ABS standard on all color options.
FAST FORWARD
Equipped with a 5-speed transmission for quick acceleration and smooth cruising.
2020 Indian Scout Sixty Photos​
2020 Indian Scout Sixty Videos
The post 2020 Indian Scout Sixty [Model Overview] Copy appeared first on webBikeWorld.
