2020 Indian Roadmaster [Model Overview]
2020 Indian Roadmaster​
The 2020 Indian Roadmaster is a touring motorcycle that has been honed to perfection through years of evolution and development. Powered by a Thunder Stroke 116 engine, there is more than enough torque at 126 lbs-ft to be able to conquer any highway, interstate, or freeway.
As a premium touring bike, the Roadmaster comes packed with features and amenities. Individually controlled passenger and rider heated seats, heated grips, highway bars, a 7 inch infotainment screen and system that comes standard with navigation, and a 200 Watt four speaker sound system for both rider and passenger to listen to music on the road.
The passenger also has a backrest built into the top box on the back of the motorcycle, which is part of its impressive 37 gallons of storage capacity. Standard electronics and driver aids include ABS, TPMS, electronic cruise control, electronically controllable rear shock adjustment (air ride system), and LED lights all around.
The 2020 Indian Roadmaster starts at $29,999 US/$36,499 CDN.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Roadmaster in one place.
  • Price: $ 29,999 US/$36,499 CDN.
    • Cruise control
    • ABS
    • Low Seat Height
Key Specs​
  • Engine type: 1811 cc, Thunder Stroke 116 v-twin
  • Power: 126 ft-lb
  • Wet weight: 405 kg
  • Seat height: 26.5 in
Key Competitors​
2020 Indian Roadmaster Specifications​
ENGINE
Engine1811 cc, Thunder Stroke 116 v-twin
Power126 ft-lb
Bore x Stroke4.063″ x 4.449″ (103.2mm x113mm)
Compression Ratio11:1
Fuel SystemClosed loop fuel injection / 54 mm bore
Lubrication
DRIVETRAIN
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearSingle Shock w/ Air adjust
Brakes FrontDual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes RearSingle / 300 mm Floating Rotor / 2 Piston Caliper
Tires FrontDunlop® Elite 3 130/90B16 73H
Tires Rear
Dunlop® Elite 3 Multi-Compound 180/60R16 80H
Fuel Tank Capacity5.5 gal (20.8 L)
ColorThunder Black Pearl, Burgandy Metallic, Pearl White Over Titanium Metallic, Titanium Smoke Over Thunder Black Smoke
ELECTRICAL
Ignition
HeadlightLED
DIMENSIONS
Overall Length104.6 in (2,656 mm)
Overall Width39.4 in (1,000 mm)
Overall Height58.7 in (1,491 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.5 in (140 mm)
Seat Height26.5 in (673 mm)
Wet Weight893 lbs / 926 lbs (405 kg / 420 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2020 Indian Roadmaster Features​
THUNDER STROKE 116 V-TWIN ENGINE
The Thunder Stroke 116 engine produces 126 ft-lb of torque for exceptional power at low RPM and a smooth ride at any speed.
RIDE WITH CONFIDENCE
Outstanding steering geometry and a lightweight cast aluminum frame come together to provide responsive handling and agile cornering.
INDIAN MOTORCYCLE RIDE COMMAND
The largest, fastest, most customizable system on two wheels, it features turn-by-turn navigation with intuitive destination search capabilities, Bluetooth connectivity, vehicle information, plus connected traffic and weather overlays to keep you on the road longer.
37+ GALLONS OF CARGO SPACE
Protect your cargo from the elements in weatherproof storage with remote-locking saddlebags, trunk, and easy access storage in the lowers.
OPTIMIZED AIRFLOW VENTS
New redesigned lowers gives the rider significantly more cooling airflow for superior riding comfort.
PREMIUM TOURING SEAT
A plush 2-up seat with independent heat controls for both the passenger and driver guarantee you’ll go further in comfort.
PREMIUM AUDIO
High-output speakers in the fairing and trunk deliver 200-watts of crystal-clear audio. It also sports a dynamic equalizer that automatically adjusts for road, wind and engine noise.
A HIGHER STANDARD
Top-of-the-line riding amenities include LED lighting, keyless ignition, cruise-control, tire pressure monitoring, and heated grips.
PUSH-BUTTON POWER WINDSHIELD
A push-button power windshield allows you to easily change the height. Keep it low for wind in your face or raise it up to cruise in comfort.
2020 Indian Roadmaster Photos​
2020 Indian Roadmaster Videos
The post 2020 Indian Roadmaster [Model Overview] appeared first on webBikeWorld.
