2020 Indian Roadmaster Elite [Model Overview]
2020 Indian Roadmaster Elite​
The 2020 Roadmaster Elite is Indian’s top of the line touring motorcycle. As with all Roadmaster models, the Elite is powered by the Thunder Stroke 116 v-twin with 126 lbs-ft of torque, but on the Elite, it has special red highlights hand-painted on.
The body’s paint is much the same, taking 30 or more hours to painstakingly apply the multiple layers of two-tone candy with hand painted pinstripes. Premium leather commonly seen in luxury brand cars cover the seats, which are individually heated for both rider and passenger. Full aluminum floorboards for both passenger and rider, pinnacle mirrors, and a top of the line 600 Watt stereo system are just some of the features brought forth for the Elite.
The electronics for the Elite include standard ABS, TPMS, stability control, and a 7 inch infotainment system with navigation, that includes traffic and weather warnings. The Elite is also the only Roadmaster that gets a historically valanced front fender, and chromed headlight surround up front. LED lights reign supreme at all corners.
The 2020 Roadmaster Elite starts at $38,999 US/$46,999 CDN.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Roadmaster Elite in one place.
  • Price: $ 38,999 US/$46,999 CDN
    • Cruise control
    • ABS
    • Low Seat Height
Key Specs​
  • Engine type: 1811 cc, Thunder Stroke 116 v-twin
  • Power: 126 ft-lb
  • Wet weight: 417 kg
  • Seat height: 26.5 in
Key Competitors​
2020 Indian Roadmaster Elite Specifications​
ENGINE
Engine1811 cc, Thunder Stroke 116 v-twin
Power126 ft-lb
Bore x Stroke4.063″ x 4.449″ (103.2mm x113mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel injection / 54 mm bore
Lubrication
DRIVETRAIN
ClutchWet, Multi-Plate
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearSingle Shock w/ Air adjust
Brakes FrontDual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes RearSingle / 300 mm Floating Rotor / 2 Piston Caliper
Tires FrontDunlop® American Elite 130/60B19 61H
Tires Rear
Dunlop® Elite 3 Multi-Compound 180/60R16 80H
Fuel Tank Capacity5.5 gal (20.8 L)
ColorThunder Black Vivid Crystal Over Gunmetal Flake
ELECTRICAL
Ignition
HeadlightLED
DIMENSIONS
Overall Length105.4 in (2,676 mm)
Overall Width
39.4 in (1,000 mm)
Overall Height56.7 in (1,440 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.5 in (140 mm)
Seat Height26.5 in (673 mm)
Wet Weight919 lbs / 951 lbs (417 kg / 431 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2020 Indian Roadmaster Elite Features​
MADE FOR THE FEW
Each Roadmaster Elite undergoes a 30-hour paint process finished by hand, featuring a brilliant two-tone candy with custom off-set red pinstripes. A limited number of these works of art will be made for a truly one-of-a-kind riding experience.
RESPECT THE PAST, EMBRACE THE PRESENT
An iconic valanced fender and illuminated headdress combine with a 19” precision machined wheel to complete the custom look.
BUILT TO OUTPERFORM
The Thunder Stroke 116 engine, featuring premium red design details, produces 126 ft-lb of torque providing a responsive ride at any speed.
PREMIUM 600-WATT AUDIO
Integrated Powerband Plus speakers in the front fairing and rear saddlebags deliver surround sound audio with crystal clarity.
THE NECESSITIES, AND MORE
Control at your fingertips. With the push of a backlit button, activate rider and passenger heated handgrips, or raise or lower the flare windshield to your preferred position.
END-TO-END ELITE AMENITIES
Pinnacle mirrors, genuine leather accents, and spacious aluminum select floorboards combine style and function. Pathfinder LED lighting with driving lights illuminates the road for safe riding, day or night.
CONTROLLED COMFORT
A plush, genuine leather 2-up heated seat, with controls for both the passenger and driver, plus passenger armrests to get you and your passenger there in comfort.
RIDE COMMAND CONTROLS IT ALL
Choose between three ride modes, Tour, Standard and Sport, for an experience that’s customized to your riding style. Use new connected traffic and weather overlays to plan every ride to avoid traffic and poor weather conditions, keeping you on the road longer.
37+ GALLONS OF CARGO SPACE
Keep your cargo protected inside spacious, weatherproof storage with remote-locking saddlebags and trunk. You can lock /unlock them via a console mounted button or with the bike’s key fob.
2020 Indian Roadmaster Elite Photos​
2020 Indian Roadmaster Elite Videos
The post 2020 Indian Roadmaster Elite [Model Overview] appeared first on webBikeWorld.
