2020 Indian Roadmaster Dark Horse [Model Overview]
2020 Indian Roadmaster Dark Horse​
The 2020 Indian Roadmaster Dark Horse brings the attitude packed alongside all the amenities of the Roadmaster. Powered by the Thunder Stroke 116 v-twin, the Dark Horse has the same 126 lbs-ft of torque, but a more rowdy exhaust note.
Standard amenities include individually controlled passenger and rider heated seats, heated grips, highway bars, a 7 inch infotainment screen and system that comes standard with navigation, and a powerful stereo system with 4 speakers. ABS, TPMS, cruise control, and LED lights all around complete the features package.
Where the attitude comes from is matte paint options, passenger long pegs instead of footboards, and a blacked out engine with subtle buffed steel highlights showing through.
The 2020 Indian Roadmaster Dark Horse starts at $28,999 US/$35,499 CDN
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Roadmaster Dark Horse in one place.
  • Price: $ 28,999 US/$35,499 CDN
    • Cruise control
    • ABS
    • Low Seat Height
Key Specs​
  • Engine type: 1890cc, Thunder Stroke® 116, v-twin
  • Torque: 126 ft-lb
  • Wet weight: 394 kg
  • Seat height: 25.5 in
Key Competitors​
2020 Indian Roadmaster Dark Horse Specifications​
ENGINE
Engine1890cc, Thunder Stroke® 116, v-twin
Torque126 ft-lb
Bore x Stroke4.063″ x 4.449″ (103.2mm x113mm)
Compression Ratio11:1
Fuel SystemClosed loop fuel injection / 54 mm bore
Lubrication
DRIVETRAIN
ClutchWet, Multi-Plate
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearSingle Shock w/ Air adjust
Brakes FrontDual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes RearSingle / 300 mm Floating Rotor / 2 Piston Caliper
Tires FrontDunlop® American Elite 130/60B19 61H
Tires RearDunlop® Elite 3 Multi-Compound 180/60R16 80H
Fuel Tank Capacity5.5 gal (20.8 L)
ColorThunder Black Smoke, Ruby Smoke, White Smoke
ELECTRICAL
Ignition
HeadlightLED
DIMENSIONS
Overall Length102.1 in (2,593.3 mm)
Overall Width39.4 in (1,000 mm)
Overall Height58.7 in (1,491 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.1 in (130 mm)
Seat Height26.5 in (673 mm)
Wet Weight868 lbs / 900 lbs (394 kg / 408 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2020 Indian Roadmaster Dark Horse Features​
THUNDER STROKE 116 V-TWIN ENGINE
The Thunder Stroke 116 blacked-out engine produces 126 ft-lb of torque for exceptional power at low RPM and a smooth ride at any speed.
RIDE CONFIDENTLY
Outstanding steering geometry and a lightweight cast aluminum frame come together to provide responsive handling and agile cornering.
INDIAN MOTORCYCLE RIDE COMMAND
The largest, fastest, most customizable system on two wheels, it features turn-by-turn navigation with intuitive destination search capabilities, Bluetooth connectivity, vehicle information, plus connected traffic and weather overlays to keep you on the road longer.
37+ GALLONS OF CARGO SPACE
Protect your cargo from the elements in weatherproof storage with remote-locking saddlebags, trunk, and easy access storage in the lowers.
OPTIMIZED AIRFLOW VENTS
New redesigned lowers provide the rider with significantly more cooling airflow for superior riding comfort.
SEATING THAT GOES THE EXTRA MILES
The standard extended reach, gunfighter style, Rogue seat guarantees you’ll travel further in comfort.
PREMIUM AUDIO
High-output speakers in the fairing and trunk deliver 200-watts of crystal-clear audio. It also sports a dynamic equalizer that automatically adjusts for road, wind and engine noise.
FEATURES FOR THE WIN
Amenities include LED lighting, keyless ignition, cruise-control, tire pressure monitoring, and heated grips to make the most of every ride.
PUSH-BUTTON POWER WINDSHIELD
A push-button power windshield allows you to easily change the height. Keep it low for wind in your face or raise it up to cruise in comfort.
2020 Indian Roadmaster Dark Horse Photos​
2020 Indian Roadmaster Dark Horse Videos
The post 2020 Indian Roadmaster Dark Horse [Model Overview] appeared first on webBikeWorld.
