Soarezito
As many of you for sure I miss the option to safely and securely attach a tank bag.
Will the new model frunk cover fit the old version one?
My guess-No, since the frunk on the 2017 model is larger than the 2014 models.. (1 liter larger). You might want to check with dealer and see if part #s are the same or the dimensions for both.As many of you for sure I miss the option to safely and securely attach a tank bag.
It's defiantly not the same part number, the newer to has the brackets to tire down a tank bag. As for being 1 liter larger I'm not sure if that translated into different dimensions for the lid or if the inside is simply a different size? I don't think we'll know for sure until someone with a newer and older (or two riders with different years) actually tries putting one on the otherMy guess-No, since the frunk on the 2017 model is larger than the 2014 models.. (1 liter larger). You might want to check with dealer and see if part #s are the same or the dimensions for both.
