'19 DCT: alternative f-peg loc'n?
wowee
On Honda's 2019 NC750X/DCT R-side display pic: the silver-washered bolt between the brake pedal's toe-stub and the exhaust pipe. What's on the L-side @ that pt.? Is that a possible loc. for altern. f-pegs?
In hosp. 2 mos. w/ no end in sight, or I'd check it myself.
What is “f-peg”? What exactly is “R-side display pic”? No picture is attached to your posting.
Not everyone may understand your abreviations. If you use full words you may get more responses. If you are referencing a particular picture, post it here in the thread. Otherwise, your picture reference is ambiguous.
The bolt you are referencing attaches the exhaust pipe to the frame I believe. According to the parts diagram its only an 8mm bolt.
Definitely not strong enough to hold a footpeg and way to low anyway. It would drag on the first corner you came to. There does not appear to be a corresponding bolt on the left side.
