- Joined
- Jun 12, 2013
- Messages
- 2,915
- Reaction score
- 929
- Points
- 113
- Location
- North Central Florida
Pre laser cut keys for the 2012-2013 are hd109. Got one for my 2013. Cut it, glued with an aerosol lid and use it for the frunk.
dduelin is right...There is no ilco blank that I know of for the wave keys with a groove in the center. They make wave key blanks without the groove. You'll have to get a O.E. Honda key blank and have it cut, and epoxy it into the radio knob or aerosol lidOh, well yes, they do. Looks like I'll have to do some more research then.
Thank you.
As pointed out, a '22 takes a different key blank. I don't know if yours is the same as my '21, but @the Ferret's pictures above (post #23) show a '21 key. Read this thread, particularly post #19. I ordered a $1 key blank from Ali eggspress and will post what I think of the blank when I get it. If the blank fits in my ignition and its measurements are the same, I will probably order a bunch more (scroll around that page). There are quite a few to choose from, but for $3 or so apiece, shipped, I will take my chances. Once I have several, I will try to duplicate my key myself...the learning experience will be worth $10 to $15.Super Moderator 670cc informed me that my 2022 would have a different style of key, so neither the HD105 nor the HD109 would (probably) work. I'm still checking it out. But thanks for your response David.
I will post here what I find when I get the key. As for duplicating the profile, there are a few real locksmiths shops around here that I will talk to re price to cut the key. That is not my default, however. I plan to cut the key myself. Many years ago, in school, a fellow student looked at the Sargent Maximum Security key system used in our dorm, ground off the point of a counter sink, and used a drill press and vise to craft a master key (he simply 'added up' all the depressions and included the ones that were the same - the system is not rocket science). I have a cheap harbor fright milling machine and I will try to dupe one key with that. If I fail, I might try using an engraving machine I inherited (for jewelry) but that has some inherent problems - it reduces the size 50%. I'll post here how this works out, but the locksmiths shops are probably the way to go with a cheap blank. At least you cut the costs significantly.Let me know what you find out. Also, how would you plan on duplicating your factory keys since you probably can't get it done at the local Ace Hardware (or CAN you)?
LOL, actually, his master key unlocked more than just our dorm. When he told the dorm counselor, and was turned in, they called Sargent. A Tech guy showed up and gave the kid a box with a whole bunch of locks and keys and told him if he could devise a system that would prevent twerps like him from defeating their system, they would pay him handsomely. This is a true story - but by then the lad had moved on to other interesting projects. This was a pretty good engineering school, and I'm not sure what he ended up doing. This was almost 55 years ago....I respect your D.I.Y attitude. A master key for the dorm, huh? Hope no one was expelled
Many of those tunnels were steam tunnels - they carried asbestos covered pipes to deliver heating steam to various buildings. Not a healthy environment.From fall of '70 thru spring of '72, I lived in a dorm at OSU....
