Is there less work in checking the clearance with a feeler gauge compared to actually adjusting the clearances? ie do you have to strip more stuff off the bike to make the adjustments?
Mike
The preparations needed to check the clearances vs adjusting them is the same. Once you are at the point of measuring the gaps, the next step would be to simply adjust them if they are wrong, right then and there.
Greg
