drmud
anyone mounted honda power outlet, looking for the spot they plug into on the nc700 that is switched? a copy of the install sheet would be great. setting up my bike with electrical. thanks drmud
Is there any way to connect a simple two usb 12v power supply that we can find in ebay with the subhurness and provide power only when the motorcycle is on?
Yes, it is. You will need the subharness (08A71-MGS-D30) and relay (08A70-MGS-D30). You will plug the relay in the fuse box and the subharness in the Option6P connector. The subharness will give you room for 4 accesories. You can connect your USB socket in one of these.
Another option is to buy just the relay and do some DIY job to plug your socket directly to the Option6P connector. In this case, you will find the wiring map in your CD shop manual. Feel free to ask any cuestion if you don't understand it
Ask for the subharness and relay at your dealer, they are not expensive. I bought mines online at Web!ke
I purchased the genuine subharness and relay but they do not have installation instructions. Where can I find these.
I have been looking for the wiring map. Where would I get a CD shop manual. The manual I got with the bike is a User manual.
