Little Ed
I have begun my quest to lower my bike so that more than my toes touch the ground. I installed a set of lowering links I fabricated and now find the rear of the bike is not as firm when pushing down on the rear of the bike. My question is what should I do to to re-establish the firmer suspension as it was with the stock link?
The stock link is 133 mm. When settting on the side kickstand (with the OEM link), the rear of the bike is solid and does not compress down very easily, unless a substantial amount of pressure is applied vertically. My initial link set was drilled at 145mm(on-center), which dropped the bike 1 3/8" (measured vertically from rear axle to upper frame). With the stock kickstand, this was too much of a drop and did not allow enough lean over to solidly hold the bike. I then fabricated another set of links at 140.5 mm which dropped the rear only 7/8". This 7/8" of drop puts me flat footed on the ground and puts the bike at a decent "lean-over" angle and feels fairly secure (except for the issue I note below).
Now that I have lowered the bike, I have noticed that a very slight amount of downward pressure on the bike results in the bike frame dropping 1/2" or so. It essentially drops enough so that the leanover angle is reduced further, impacting it's stability on the side kickstand. Long term I will address the kickstand length, once I finalize the link length that best suits me however, I am concerned about the new ''mushiness of the rear suspension" created by the non-stock length link.
It appears that the longer link drops the bottom of the shock and this reduces the preload on the shock spring, reducing the initial or static firmness of the rear suspension. How do I reestablish that firmness. My initial thoughts are to tighten the spanner nuts, but it appears that that tightenting the spanner nuts will bring the bike frame back up, thus requiring the link holes to be lengtened further.
Is anyone familiar with the interaction of the shock preload and link length- and how the bike can be lowered without leaving the rear suspension softened?
