trjerm
- Joined
- Jun 25, 2022
- Messages
- 211
- Reaction score
- 302
- Points
- 63
- Location
- Sierra Nevada foothills
Looks good, and I’m sure it’s a bIg improvement. I have an Ohlins waiting to go on. How long did it take you to remove and put in the new shock? Thanks.
Hmm. My Nc is a 2021. I believe the shock length is longer than the earlier ones. Even so it’s going to be about 10 mm longer. I guess I’ll just have to try it and see how it fits.As you can see , I put it up on the centerstand, and removed the rear wheel and exhaust, before I tackled the shock . The stock shock was easy to remove , about an hr. But the Penske is a pain , because it's 12mm longer and was hitting the centerstand w the sub assy so I hand to remove that and grind it and Now I need some adjustable lowering links , so putting stock shock back on. But if your Ohlins is 310 mm eye to eye you should be able to do it in 2-3 hrs max , top shock bolt is a PIA
Still on stock rear shock, but I have the preload maxed out, which raises ride height a bit, and it helped significantly. Geometry from front to rear ride height plays a big part in handling. Before I maxed out preload, it felt like it want to push wide through turns on the track. Then when I got the forks built, it was a whole game changer. On track, might I add. I have a bone stock 2016 NC700X that I ride on street and only thing I have done to it is maxed the preload on the rear shock and it handles plenty fine for me - on the street. No desire for any suspension mods on the street NC.TacomaJD , what rear shock did you use along with the race tech gold valves , I'm toying with the Idea of using 94-97 VFR internals with gold valves in front forks just to get adjustable preload and I have lot's of VFR parts
Nice photo. Do you have the stock footrests on your Nc? I realize that the suspension is higher on the pre 21s, but the footrests on mine ground very easily.I can attest to Race Tech Gold Valve Emulators and fork springs specific to rider weight drastically improving handling. If you have to replace fork seals, might as well throw those goodies in too! That's what I did when my forks began leaking. Well, I let Thermosman Suspensions do the work for me. Lol
Well I have a 30mm peg riser on the right peg, and still drag it at times, but the left peg is removed completely and I utilize a highway peg mounted on the front frame rail. I am a left leg below knee amputee and that knee is trashed and won't bend past 90°. It's a goofy setup and looks weird as hell on track, but it works quite well for me given the circumstances.Nice photo. Do you have the stock footrests on your Nc? I realize that the suspension is higher on the pre 21s, but the footrests on mine ground very easily.
How suited is the gearing for The Gap? I imagine with good tires and the right gearing an Nc should rail through.
Yes, likely so. The leaning tree gives it away. This particular day we only saw one bike on both the Foothills Parkway and the Dragon. Light rain, cold and foggy.That must be one of the most famous photographed corners in the world. View attachment 50045
Kudos for continuing to ride with such skillful aggression. Apart from riding skills you obviously have athletic ability. For the life of me I find it difficult to understand how you can drag your right knee considering the limitations of your left leg.Well I have a 30mm peg riser on the right peg, and still drag it at times, but the left peg is removed completely and I utilize a highway peg mounted on the front frame rail. I am a left leg below knee amputee and that knee is trashed and won't bend past 90°. It's a goofy setup and looks weird as hell on track, but it works quite well for me given the circumstances.
The static ride height is also a little higher now with the new fork springs and the rear shock preload maxed out.
