Exploring The Beastly 2023 MV Agusta Brutale 1000 RR
The 2023 MV Agusta Brutale 1000 RR is a masterpiece with cutting-edge technology, breathtaking power, and striking aesthetics. The heart of the Brutale 1000 RR is a 998cc inline-four engine that is shared with other bikes in the MV Agusta line. Delivering an astounding 208 horsepower, it is the top of the food chain in the MV family. To harness the raw power of the Brutale 1000 RR, MV Agusta has equipped this superbike with state-of-the-art technology. The advanced electronics package includes a six-axis inertial measurement unit (IMU) that constantly monitors the motorcycle’s motion and provides precise data to optimize traction control, cornering ABS, and the quick-shifter system.
Typical of Italian motorcycles, and like other bikes in the 2023 MV Agusta family, looks and function are a top priority and the Brutale doesn’t disappoint. The aerodynamic fairings not only enhance the motorcycle’s visual appeal but also improve its performance by reducing drag and increasing stability at high speeds.
While the Brutale 1000 RR is built to dominate the track, MV Agusta has not compromised on rider comfort. The ergonomics have been carefully designed to provide a balanced riding position that minimizes fatigue during long rides. The adjustable footpegs and handlebars allow you to tailor the bike to your preferences, ensuring a personalized fit that enhances control and confidence.
The Brutale 1000 RR is equipped with top-of-the-line suspension components and braking system to complement its blistering performance. The fully adjustable Öhlins suspension delivers superb handling and the Brembo braking system, with its powerful monobloc calipers and dual front discs, provides exceptional stopping power.
The 2023 MV Agusta Brutale 1000 RR starts at $37,798 USD/$40,748 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Brutale 1000 RR in one place.
- Price: $37,798 USD/$40,748 CAD
- 998 cc with 208 horsepower
- Carbon fiber bodywork
- Lightened crankshaft
- Launch control
- Engine: 998 cc Four cylinder, 4 stroke, 16 valve
- Power: 208 horsepower
- Torque: 85 ft-lbs
- Weight: 410 lbs (186 kgs)
- Seat Height: 33.3 inches (845 mm)
2023 MV Agusta Brutale 1000 RR Specifications
Engine | 998 cm3 (60.9 cu. in.), Four cylinders, 4 stroke, 16 valves, with countershaft |
Power | 208 Hp |
Bore x Stroke | 79 mm x 50.9 mm (3.1 in. x 2.0 in.) |
Compression Ratio | 13.4:1 |
Timing system | “D.O.H.C”, radial valve and DLC tappet |
Color | ROSSO EDONISTA OPACO, NERO CARBON METALLIZZATO OPACO, NERO CARBON METALLIZZATO OPACO, ROSSO MAMBA |
Clutch | Wet, multi-disc with back torque limiting device and Brembo radial master cylinder/lever assembly |
Transmission | Cassette style; six speed, constant mesh |
Final Drive Ratio | 15/41 |
Suspension Front | Öhlins Nix EC hydraulic “upside down” front forks with TiN superficial treatment. Completely adjustable with electronically controlled compression and rebound damping with manually controlled spring preload. |
Suspension Rear | Progressive, single shock absorber Öhlins EC TTX completely adjustable with electronically controlled compression and rebound damping and spring preload |
Brakes Front | Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and aluminium flange – Brembo radial master cylinder/level assembly |
Brakes Rear | Single steel disc with Ø 220 mm (Ø 8.66 in.) dia.- Brembo PS13 brake master cylinder |
Tires Front | 120/70 – ZR 17 M/C (58 W) |
Tires Rear | 00/55 – ZR 17 M/C (78 W) |
Fuel Tank Capacity | 16 l (4.23 U.S. gal.) |
ABS System | Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function |
Battery | Li-ion 12 V – 4.0 Ah |
Voltage | 12 V |
Alternator | 350 W at 5.000 r.p.m. |
Headlight | |
Tail Light | |
Overall Length | 2.080 mm (81.89 in.) |
Overall Width | 805 mm (31.69 in.) |
Trail | 97 mm (3.82 in.) |
Wheelbase | 1.415 mm (55.71 in.) |
Ground Clearance | 141 mm (5.55 in.) |
Seat Height | 845 mm (33.27 in.) |
Dry Weight | 186 kg (410.06 lbs.) |
Warranty | |
Extension |
2023 MV Agusta Brutale 1000 RR Features
Electronics
Thanks to the high-tech inertial platform, traction and wheelie controls are even more effective and precise, which improves safety but also with the utmost attention to obtaining the best possible performance. The arrival of the throttle with counter rotation improves control in mid turn and makes cruise control deactivation more progressive. Torque, traction and launch control management have been updated and further perfected.Technology
The use of titanium for the connecting rods and for the intake and exhaust valves is an indication of the high quality that characterises the Brutale project. ThAr interface is also a point of excellence thanks to the 5.5″ TFT panel, the multifunction electrical controls and the MV Ride App, which allows you to set numerous electronics and engine parameters directly from your smartphone. The Front Lift Control works on the angular velocity to manage wheelies smoothly and effectively, preventing abrupt drops in power. And the engine is always correctly lubricated thanks to the semi-dry sump.Safety
The Continental ABS with cornering function is the culmipation of a oohs evolution aimet-aproving Tided passenger safety. The braking system is number one in terms of power and ease of handling, thanks to the wide diameter discs, Brembo Stylema callipers and the radial pump at the handlebar. To improve ergonomics, the saddle has been redesigned, while the footrests are forged: lightweight and functional.2023 MV Agusta Brutale 1000 RR Photos
2023 MV Agusta Brutale 1000 RR Videos
2023 MV Agusta Brutale 1000 RR Review by The Bike Show:
2023 MV Agusta Brutale 1000 RR review by oneonly xram:
MV Agusta Websites
Other Links
The post 2023 MV Agusta Brutale 1000 RR [Specs, Features, Photos] appeared first on webBikeWorld.
