The 2023 Moto Guzzi V100 Is A Classy Yet Capable Travel Companion
Moto Guzzi first introduced the V100 series to its class-filled lineup in 2022, and you guessed it, the bike is back for another round in 2023 – nothing seems to be changed, but given how new the bike is, we aren’t complaining. One fresh addition for this year is the introduction of the Aviazione Navale limited edition ( more on that later).
The full name of the bike is the Moto Guzzi V100 Mandello, which retrieves its namesake from the town that Moto Guzzi has called home since 1921 – Mandello del Lario.
Digging deep into the Italian-made V100 reveals a 1042cc V-Twin, which produces a claimed 115 hp and 77 lb-ft of torque at its peak. Weighing in at 513 lbs, the V100 may not be built for land speed records, but it’s sure to provide ample fun along the way.
It’s true that there isn’t much on the market that looks like a Guzzi, and the V100 Mandello is absolutely no exception. The bike features an adventure-inspired take on the legendary Moto Guzzi design language, complete with a handful of details in the fairings inspired by the Italian brand’s efforts at Le Mans.
For 2023 the V100 is offered in three unique packages – the standard Mandello, the premium Mandello S, and the ultra-limited edition Aviazione Navale – a bike which features a unique livery inspired by the air division of the Italian Military Marine, which Moto Guzzi’s founders were members of. The Aviazione Navale is only being produced in a 1913 bike run, a homage to the year the force was founded.
The standard Mandello model features a preload and rebound adjustable front fork setup and an adjustable monoshock in the rear. A full set of Brembo brakes are standard, and the bike is equipped with a variety of electronics, including a suite of rider aids and an electronically adjustable windshield.
Meanwhile, the upgraded S model receives a few premium features, including Ohlins semi-active suspension, heated hand grips, and a TPMS sensor system.
Additionally, the S is offered in two unique colour schemes – Verde 2121 and Grigio Avanguardia, whereas the basic model is offered in Rosso Magma and Bianco Polare
The 2023 Moto Guzzi V100 Mandello starts at $15,490 USD/$17,990 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc., so you can read up on the new 2023 Moto Guzzi V100 Mandello/S/Aviazione Navale in one place.
- Price: $15,490 USD/$17,990 CAD
- Full LED headlight
- Full-Colour TFT Dashboard
- Adaptive aerodynamics
- Multiple Riding Modes
- Engine: 1042cc V-Twin
- Power: 115 HP
- Torque: 77 lb-ft
- Weight (Wet): 513 lbs (232.7 kg)
- Seat Height: 32.08 in (81.5 cm)
- Kawasaki Ninja 1000SX
- Suzuki GSX-S1000GT
- Ducati Multistrada V2 S
2023 Moto Guzzi V100 Specifications
Engine | 1042cc, Transversal 90° V-twin, four valves per cylinder w/ Ride by Wire |
Engine Power | 115 hp (84.6 kW) – 8,700 rpm |
Bore x Stroke | 96 x 72 mm |
Compression Ratio | |
Fuel System | |
Starter | |
Maximum torque | 77 ft-lb – 6,750 rpm |
Clutch | |
Transmission | 6 speed |
Final Drive | |
Suspension Front | Ø 41 mm USD fork with adjustable preload and rebound damping |
Suspension Rear | Monoshock with adjustable preload and rebound damping |
Brakes Front | Twin Ø 320 mm floating discs, 4-piston Brembo monobloc radial calipers. Radial front master cylinder. Cornering ABS. |
Brakes Rear | Single Ø 280 mm disc, 2 piston Brembo caliper. Cornering ABS |
Front Wheel | Cast Aluminum 120/70 R17 |
Rear Wheel | Cast Aluminum 190/55 R17 |
Fuel Tank Capacity | 4.5 gal (0.9 gal reserve) |
Color | |
Ignition | |
Headlight | LED |
Tail Light | |
Overall Length | |
Overall Width | |
Saddle Height | |
Wheelbase | |
Ground Clearance | |
Seat Height | 32.08 in |
Kerb Weight | 513 lbs (According to guideline VO (EU) 168/2013 with all fluids, with standard equipment and fuelled with at least 90% of usable tank volume). |
Warranty | |
Extension |
2023 Moto Guzzi V100 Features
Power and versatility
The V100 Mandello is ready to give its all even at lower speeds. Its 115 horsepower and 105Nm torque at 6750 rpm are complemented by an up-down quickshifter for seamless, clutch-free gear changes and a truly dynamic riding experience.Sporting credentials to be proud of
The Moto Guzzi V100 Mandello’s compact body delivers a sporty experience on even the twistiest roads and outstanding stability and handling, making it ideal for longer trips. Whatever the scenario or required riding style, it comes up trumps in terms of resilience, precision and sheer enjoyment.Dynamic control
Öhlins Smart EC 2.0 semi-active suspension (which comes as standard with the S version) delivers exceptional control and dynamic feedback. Whether you’re bent on a sporty ride or taking to the road for a long trip, the Riding Modes function automatically adjusts the suspension for optimal performance on any type of surface and in all conditions.Technology
Category-breaking adaptive aerodynamicsThe Moto Guzzi V100 Mandello is the first motorcycle in the world to incorporate adaptive aerodynamics. More than 200 hours were spent in the wind tunnel finetuning this technology, which reduces air pressure on the rider by adjusting the position of the deflectors in line with the speed and selected Riding Mode. Riding comfort is further enhanced by adjusting the windshield.
2023 Moto Guzzi V100 Photos
2023 Moto Guzzi V100 Videos
2023 Moto Guzzi V100 Mandello S Review by Motorcycle.com
2023 Moto Guzzi V100 Mandello | First Ride by Chaseontwowheels:
Moto Guzzi Official Websites
The post 2023 Moto Guzzi V100 [Specs, Features, Photos] appeared first on webBikeWorld.
