2023 Harley Davidson Softail Standard [Specs, Features, Photos]
The 2023 Harley Davidson Softail Standard: Just Build It
There is no better way to start a custom build than with a fresh blank canvas. Welcome to the starting point for your very own American badass bike.
Within the 2023 Harley Davidson lineup, the Softail frame is the underpinning of almost half the models, and the Milwaukee-Eight® 107 V-Twin engine makes 92.5 HP and 110 ft-lb as delivered. As it sits the Softail Standard is an excellent bike to ride while you plan each stage of custom tuning you crave.
The Harley Davidson team keeps it simple. Working back from the LED Daymaker headlight you get some easy-reach mini-ape bars, lots of chrome, and a tuck-and-roll saddle. Like the Model T, it comes in black and only black.
There is only 1 color choice for the 2023 Harley Davidson Softail Standard: Vivid Black of course.
The 2023 Harley Davidson Softail Standard starts at $14,399 USD / $17,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Softail Standard in one place.
2023 Harley Davidson Softail Standard2023 Harley Davidson Softail Standard
  • Price: $14,399 USD / $17,599 CAD
    • Milwaukee-Eight® 107 V-Twin engine
    • Softail Frame
    • Excellent platform to begin a custom build
  • Engine: 107ci V-twin
  • Power: 92.5 HP (estimated)
  • Torque: 110 lbs-ft @ 3000 RPM
  • Wet Weight: 655 lbs (297 kg)
  • Seat Height: 25.8 inches (680 mm)
  • Indian Chief
  • Honda Rebel 1100
  • Harley Davidson Street Bob 114
2023 Harley Davidson Softail Standard Specifications​
Engine107 cu in, Milwaukee-Eight® 107
Engine Power92.5 HP (estimated)
Bore x Stroke3.937 in x 4.374 in.
Compression Ratio
10.0:1
Exhaust2-into-2 shotgun; catalyst in muffler
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
Dual-bending valve 49 mm telescopic with aluminum fork triple clamps; dual rate spring
Rear Fork
Hidden, free piston, coil-over monoshock; 43mm stroke; cam-style preload adjustment
Wheels, Front Type
Silver, Annihilator cast aluminum
Wheels, Rear Type
Brakes Front
4-piston fixed front
Brakes Rear2-piston floating rear
Tires Front
100/90B19,57H,BW
Tires Rear
150/80B16,77H,BW
Fuel Tank Capacity3.5 gal.
ColorVivid black
Ignition
HeadlightHigh beam
Length
91.3 in.
Trail
6.2 in.
Rake30
Wheelbase
64.2 in.
Ground Clearance
4.9 in.
Seat Height
25.8 in.
Weight, As Shipped
642 lb.
Warranty
2023 Harley Davidson Softail Standard Features​
ADJUSTABLE REAR MONO SHOCK​
Easily adjustable mono-shock rear suspension allows for dynamic cornering while preserving the hardtail look.
TANK​
Featuring a 2023 waterslide tank graphic.
DAYMAKER® SIGNATURE LED FORWARD LIGHTING​
Powerful beam of natural color white light cuts through the night and is easy on the eyes.
2023 Harley Davidson Softail Standard Photos​
2023 Harley Davidson Softail Standard 2023 Harley Davidson Softail Standard 2023 Harley Davidson Softail Standard 2023 Harley Davidson Softail Standard
2023 Harley Davidson Softail Standard Videos​
2023 Harley-Davidson Softail Standard – FIRST LOOK!!!
2023 Harley-Davidson Softail Standard, the bike customizer’s perfect platform
The post 2023 Harley Davidson Softail Standard [Specs, Features, Photos] appeared first on webBikeWorld.
