2023 Honda NC750X DCT [Specs, Features, Photos]
The 2023 Honda NC750X DCT: For Adventure Addicts
If you are in the market for a reliable, versatile, and stylish adventure motorcycle? Look no further than the 2023 Honda NC750X DCT! This Japanese bike is the perfect choice for those who love to explore the great outdoors, but also want a comfortable ride for their daily commutes.
For 2023, Honda has dropped the clutch lever from the NC750X. All gear changes come via the smooth Six-speed Automatic Dual Clutch Transmission (DCT). This makes for a much more relaxed and enjoyable ride, whether you’re cruising down the highway or navigating through tight city streets.
Power comes from a liquid-cooled, SOHC 8-valve parallel-twin engine, measuring 745cc. Putting 58 hp and 51 lb-ft of torque to the rear tire, the NC750X has no issues getting up and going all while delivering a miserly 67mpg.
The NC750X features four selectable engine power-delivery modes: Standard, Rain, Sport, and an additional user-customizable setting. Honda has added Selectable Torque Control (HSTC), ABS brakes, a plush seat, and a huge 23-liter utility compartment that’s big enough to hold a full face helmet round out this killer commuter package.
The 2023 Honda NC750X DCT starts at $9,399 USD / $11,997 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda NC750X DCT in one place.
2023 NC750X Matte Nightshade Blue
  • Price: $9,399 USD / $11,997 CAD
    • Automatic Dual-Clutch Transmission (DCT)
    • Anti-Lock Brakes (ABS)
    • 23-liter Utility Compartment
    • Honda Selectable Torque Control (HSTC)
    • 4 Ride Modes
    • Low Seat Height
    • ABS Brakes
    • Low Profile Windscreen
  • Colors: Matte Nightshade Blue
Main Specs​
  • Engine: 745cc liquid-cooled four-stroke 55º parallel-twin
  • Power: 58 horsepower
  • Torque: 51 lbs-ft at the crank
  • Wet Weight: 493lbs (224 kg)
  • Seat Height: 31.5 inches (800 mm) at lowest point
Competitors​
  • BMW F750 GS
  • Kawasaki Versys 650
  • Suzuki V-Strom 650
  • Moto Guzzi V85TT
  • Triumph Tiger Sport 660
2023 Honda NC750X DCT Specifications​
Engine745cc liquid-cooled four-stroke 55º parallel-twin
Power58 HP
Bore x Stroke77.0mm x 80.0mm
Compression Ratio10.7:1
InductionPGM-FI; 36mm throttle body
Valve TrainSOHC; four valves per cylinder
Clutch
TransmissionSix-speed Automatic Dual Clutch Transmission (DCT)
Final Drive#520 Chain; 17T/41T
Suspension Front41mm Showa telescopic fork; 4.7-inch travel
Suspension RearPro-Link® single shock; 4.2-inch travel
Brakes FrontSingle 320mm wave disc; 2-channel ABS
Brakes RearSingle 240mm wave disc; 2-channel ABS
Tires Front120/70ZR-17 radial
Tires Rear160/60ZR-17 radial
Fuel Tank Capacity3.8 gallons
ColorMatte Nightshade Blue
IgnitionDigital transistorized with electronic advance
Headlight
Tail Light
Overall Length
Ground Clearance
Trail4.3 inches
Wheelbase60.1 inches
Rake (Caster Angle)27.0°
Seat Height31.6 inches
Curb Weight493 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
2023 Honda NC750X DCT Features​
CONVENIENCE​
INTEGRATED STORAGE COMPARTMENT
The 2023 NC750X offers a large 23-liter utility compartment that’s big enough to hold most dual-sport full-face helmets with a visor, and then some. Secure and convenient, you’ll use it every time you ride.
AUTOMATIC DUAL-CLUTCH TRANSMISSION (DCT)
Shift with the push of a button, or select the NC750X’s automatic mode and the bike will shift itself. Our Automatic DCT offers three riding modes as well, depending on the kind of performance you want. It’s been a huge hit on our other models, and once you ride an NC750X with DCT, you’ll see why.
UNDER-SEAT FUEL TANK
The under-seat fuel tank centralizes mass and enhances overall handling. Locating the tank and filler underneath the passenger seat allows for innovative centralized storage between the front of the seat and the handlebar.
TECHNOLOGY​
Honda SELECTABLE TORQUE CONTROL (HSTC)
With Honda Selectable Torque Control (HSTC) you can choose a level which allows some rear-wheel spin—on gravel or dirt for instance—or pick a second level which reduces wheel spin, particularly on slippery roads. It’s a great feature that helps make the NC750X even more versatile.
THROTTLE BY WIRE
The NC750X features throttle-by-wire (TBW) technology. That also lets us give you four selectable engine power-delivery modes: Standard, Rain, Sport, and an additional user-customizable setting.
FRONT SUSPENSION
You get a perfect balance between a long-distance and a short-hop street machine. This gives it a wide range of capability, good handling and helps inspire confidence.
DISC BRAKES WITH COMBINED ABS
Single front and rear disc brakes give the NC750X great stopping power. Now standard on all NC750X models, you’ll get ABS brakes that are linked rear-to-front for added stopping power, even under challenging conditions.
LCD INSTRUMENT PANEL
Full digital LCD instrumentation includes digital speedometer, digital bar-type tachometer, clock, low-fuel gauge and two trip meters. Plus, the tach bar graph changes color according to fuel consumption, RPM, gear position and more.
PERFORMANCE​
PARALLEL-TWIN ENGINE
The NC750X’s engine is a big step forward in modern powerplant design. The two-cylinder format produces tons of low- and mid-range torque, and the 270-degree-phase crank and uniaxial primary balancer make it smooth, too.
SLIPPER CLUTCH
On our manual-transmission NC750X, you get a slipper clutch that helps eliminate wheel hop under downshifting, and which also lightens clutch-lever pull by 20 percent.
CAST ALUMINUM 17-INCH WHEELS
The 17-inch wheels give you a wide choice of premium tires to choose from and really help the NC750X offer responsive handling in turns. The cast wheels are light and strong, and look great too.
ELECTRONIC FUEL INJECTION
Electronic Fuel Injection means easy start-ups on cold mornings and flawless running even at high elevations.
PRO-LINK® HMAS REAR SUSPENSION
Teamed with a Honda Multi-Action System (HMAS) rear shock, the NC750X eats up the gnarliest pavement while giving you a smooth ride.
STEEL TRUSS FRAME
Light, strong and with just the right amount of stiffness, the NC750X’s rigid and compact chassis is the foundation for precise handling.
COMFORT​
LOW-PROFILE WINDSCREEN
The NC750X offers just the right amount of bodywork—enough to offer good wind protection, but not so much that the bike feels heavy or wide.
LOW SEAT HEIGHT
The NC750X’s seat height helps make it even more rider friendly in traffic or in parking lots.
STREAMLINED COWL AND BODYWORK
The cowl offers better wind protection, and the sharp-edged styling freshens up the bike’s look too.
EXTRA COMFORTABLE SEAT
On a bike like the NC750X, you’ll probably want to extend your adventures and take some longer trips. That’s why we gave it a seat with a shape that’s both supportive enough for cornering and comfortable even when the miles stack up.
ADVENTURE-READY ACCESSORIES
Because the NC750X is so versatile, we offer a wide range of Honda accessories to help you custom tailor it for your adventures. Choose from top-box carriers, USB ports, tall windscreens, centerstands, cowl guards, saddlebags, heated grips and much, much more.
2023 Honda NC750X DCT Photos​
2023 Honda NC750X DCT 2023 Honda NC750X DCT
2023 Honda NC750X DCT Videos​
2023 NC750X DCT Walk Around
2023 Honda CRF1100L NC750X DCT – The bikes that will rule the roads!
Honda Websites​
Other Links​
The post 2023 Honda NC750X DCT [Specs, Features, Photos] appeared first on webBikeWorld.
Gee Honda. The 2023 is available with DCT only so maybe edit the part about the 6 speed manual’s slipper clutch.
Regarding American Honda’s mention of a slipper clutch on the manual transmission NC750X (not even offered in the USA for 2023) under the Features list of the NC750X DCT, I wrote the following letter to American Honda:
“I have a suggestion. On powersports.honda.com for the USA market, under 2023 NC750X DCT > Features > Performance, the following is shown:
"SLIPPER CLUTCH
On our manual-transmission NC750X, you get a slipper clutch that helps eliminate wheel hop under downshifting, and which also lightens clutch-lever pull by 20 percent."
Since the manual transmission NC750X is no longer offered in the USA for 2023, it seems pointless and perhaps confusing to some people that the web site describes updates to the manual clutch that they can't get anyway. I suggest you delete that paragraph. Several members of NC700-forum.com noticed this error.”
This is the response I got from Honda:
“Thank you for submitting your suggestion to American Honda Powersports Customer Relations. We understand you would like to see a “slipper clutch.”
We will document your feedback for further review by our product development team.
Sincerely,
American Honda Motor Co., Inc.
Powersports Customer Relations”
Suffice it to say that communicating a suggestion to American Honda is a rather hopeless mission.
Cant understand why it doesn't have a temp gauge, scratching my head on that omission. :confused::confused:
I wonder how good the "plush" seat is? Could one order such a seat for their older, say 2021, NC?
You could order one, but you’d be the victim of colorful marketing hype. Actually Honda never used the word “plush”; the author of the article did. The part number for the 2023 NC750X rider’s seat is the same as for the 2021, 77100-MKW-D01ZA.
