bigjeff
Will a Bell Arrow helmet fit in Frunk? Anyone have one? They are on sale for like $39 - and if it fits in the frunk, I may snag one.
Probably depends on the size. I think most XXL helmets will be a tight fit, if they fit at all. Otherwise, Bell makes a good helmet for the bucks. Just make sure the 'head-shape' of the style you buy suits you.
I remember when I first started riding an old guru of mine telling me " There's two places you don't wanna be too stingy when riding an m/c... tires and helmets.
If your head is as big as mine, no way does any helmet you own fit in a frunk. However, if you are normal size you have a normal chance it will fit in a frunk. Just got to try it, no magic answer to your question.
The bike does come with a helmet lock of sorts; a cable to be attached under the pillion to then lock to your helmet's D-ring. I purchased a lockable carabiner and find it works very well. My trunk is usually full of stuff now, so I use the included helmet cable. My friend has the helmet lock from Twisted Throttle that attached to your license plate and has a lock on each side for two helmets. I think it is called the Helmet Guardian.
This is what I also use, works great!!Instead of buying a helmet lock,and I really don't like the short cable I am going with a gun lock.I had a extra laying around.its longer,can go through the face shield or d ring.can be locked to frame,lower footpeg.it will fit behind the gas tank it that space above rear light,or frunk.
