Tutorial for steering head bearings replacement
vincent
Nantes, France
vincentrobic.me
Hi,
There are not a lot of tutorials about steering head bearings for the NC series. So here's mine, if anyone is interested.
The stock bearings broke at 50k kilometers (about ~31000mi.), maybe because of pressure washer. Although I sometimes use it, I'm not really a pressure washer addict, but the previous owner could have been! I replaced the roller bearings with tapered ones from All Balls.
http://vincentrobic.me/2015/12/03/remplacement-roulements-colonne-direction-honda-nc700x
It's still in French but there are a lot of pictures.
Great work, and great write up. You could create the ultimate NC700 service manual!
Hello I know it is is longtime ago but I'm looking for Vincent's tutorial. The url is not valid anymore. I can restore only text without pictures from web archive. Any one please maybe got it in pdf. Thanks a lot.
Hi,
I don't use this forum anymore. So if anyone is interested in my tutorials, just PM me your email address and I'll send you a PDF copy of all the tutorials. Feel free to share them so that it can help more people!
Here are all of Vincent's tutorials. They are all in French, but I translated the titles.
  • Maintenance Schedule.pdf
  • Valve Clearance Adjustment.pdf
  • Steering Column Bearing Replacement.pdf
  • Chain Replacement.pdf
  • Fork Oil Replacement.pdf
  • Rear Wheel Bearing Replacement.pdf
  • Air Filter Replacement.pdf
  • Draining Crankcase.pdf
  • Bleeding Brake Fluid.pdf
  • Brake Pad Replacement.pdf
