Trunk Lock Recall
Old Can Ride
Webster, Texas
If your motorcycle is on the recall list and you are the person who bought the bike new, Honda will send you a letter. If not 1st owner you will have to call Honda service.
Juggler
Moscow
it is better to diy lock using metal like this
the problem is plastic notch
Therapy
West Central Fl.
OH yea, forgot. He is the first owner - a 2014. The other son has the used 2012.
MiG Angel
Gonzales
That would explain why I haven't received any recall letters. Bought the bike with 3,500 miles from the dealer. I've neglected to change the display to fix the trip meter issue and I won't go to the dealer unless the trunk gets stuck closed.
RedOkami
Rochester
OMG do you have contacts for that metal replacement part? Cuz that's SO what I need!!
Where or what website or whatnot?!?
I've contact Honda a few times to see if they have a replacement for mine because I have had a similar issue to ya'll as well but honda's about as helpful as an umbrella in a hurricane.
Thx
greenboy
I know this is a zombie², but does anybody know where you can get METAL parts like below, for the frunk lock mechanism? Buying the original one again is just treating a symptom and not the cause.
Therapy
West Central Fl.
My son has a 2014 and did not get a notice.
We do press down on the lid when opening so as to relive the pressure on the mechanism with thanks to this thread.
I hate that lame f***kin' frunk latch lock furiously.
I own two 2012 Xs and never had a frunk latch problem. Does the issue affect only certain model years? Like Therapy said, I always press down on the frunk lid on rear seat/rack to release pressure on the latch when opening.
greenboy
Likewise. I think but am not sure that the mechanism still has that weak delrin part.
greenboy
Opened up the front center cover area and messed with my frunk latch lock until I got it to work again, at least for a while. I think what was happening is that the u-shaped latch part on the frunk lid was having trouble reaching far enough into the main assembly to trigger the bit that when depressed by it then rotates a hook over it. So I grinded out a little on the upper/inside part of the bottom of the u and squished the two sides of it incrementally with vise-grips until the bottom of the u bent a bit rounder and reached in further.
So with mine anyway, it does not seem like it's an issue with the cable actuating parts.
