Porko
Anyone check speedo accuracy with gps? My 700X with Metzler z8 tires is off 8 km. showing too fast. Actual speed is 5 mph slower than shown on speedo. Can Honda speed's be calibrated?
YouI was going so fast, I had no time to check the dash....
Assuming the speedometer determines speed by countershaft rotational speed, I suppose (IF there is room) you could raise the countershaft sprocket 1 tooth to 17. It would raise the gearing 6.25% and the bike would be going that much faster for a given engine RPM, thus improving the speedo accuracy. On the down side it might make 6th gear less usable by being too tall.
Greg
It does not detect on the countershaft. I can't tell exactly from the picture where it is taking it, but it appears to be from a gear within the transmission. It is bolted into a hole in the top right of the transmission.
By countershaft, I meant the transmission output shaft
My manual trans non-ABS bike reads right on with the GPS. I wonder if this is a DCT only issue. Does anyone have a DCT bike that reads right on? The primary gearing and final gearing is quite different between the two, however the overall gearing (primary x final x overdrive ratio) is very close to the same. The vehicle speed sensor reads before the final gearing so there would need to be a way to compensate in the display controller.
Using my mounted Garmin E-trex as a control, my speedo ranged from dead on to +/- 1 mph depending on the wind conditions. One of the most accurate speedos I have ever encountered on a bike.
