size of kickstand pad?
Willie
Minnesota
Does anyone know if the kickstand pad size on a 2016 is different from 2012 thru 15?
I ordered one for my 2016, and does not fit, wondering if I erred or was shipped the wrong part.
Thanks for reading
Willie.......
Can you post a link to the one you ordered that does NOT fit your bike?
I use a plastic puck I got from an Indian open house. Are you referring to one that attaches to your kickstand? With an interference fit or something?
This is what I use - metal electrical box cover, about 25 cents at Lowe's, Home Depot, Menard's, Keep it in the frunk, loop on end of string goes over end of handlebars.
I bought two cheap foot enlargers off Amazon, had both of them fall off eventually, even with tightening multiple times and using loctight, I've got a buddy of mine that's going to make one and weld it on next time
I go to home depot and get small samples of flooring. They are stiff enough to do the job, already perfectly sized, and free. I seem to forget to pick one up after use each season so I just go to the stack and throw another one in the frunk.
