Del Mar
Two questions if I may....
1. To remove the rider's seat, I assume that the two bolts at the rear outer edge are removed and it will slide or lift out?
2. To remove the belly pan, again it looks like it's just secured by one bolt either side and it then pulls away from several rubber grommets? This job is in the handbook and it reads this way. Is the pan one piece or does it dissassemble down to three pieces by any chance?
Thanks
Thanks
