melensdad
One thing that I've wanted to add was a mount for a phone. Not so much for phone use, but rather for navigational use.
I don't really like looking down at the tank or triple tree area while riding to see a map, so I wanted something that was mounted closer to the line of eyesight.
Drilled a hole into the MadStad mount and installed a Ram ball. Attached a "mid length" double ended Ram clamp, the type with the security lock, and on the end of that is Ram mounting ball with a phone case attached to that.
I mounted it OFF center on purpose. My thought is that I have room for something else in the future that can be attached to the other windscreen mount. I have Ram ball located on the outside left, it could easily be switched to the inside left to allow me to center the phone if I choose to do so.
