Nortwestrider
Does anybody make rear links to raise up the rear end ??.
Yes,I want to try the fork extensions but I would also like to raise the rear the same and gain ground clearence.I'm going to built the ulitimate ADV X this winter and ground clearence is a priority.
Thank you for your quick answer.
Now, I understand. Being short, I just can't think like you tall people!
The Soupys adjustable dog bones allow you to lower or raise the rear of the bike. Check here: NC700X Lowering Links, NC700X Lowering Kit, NC700X Lowering Link, NC700X Adjustable Ride Height, NC700S Lowering Links, NC700S Lowering Kit, NC700S Lowering Link, NC700S Adjustable Ride Height . Just request the ability to raise your rear end rather than the standard lowering only setup.
Or, if you have machining abilities and equipment, you could make your own custom shorter dogbones that will raise the bike however much you need. The nice thing about the Soupys ones are that you aren't stuck with a fixed height and it'll only cost you about $100.
