- Joined
- Nov 14, 2012
- Messages
- 587
- Reaction score
- 13
- Points
- 18
- Location
- WASHINGTON ST lakewood
new nut plates for windshield to replace the rubber well nuts that honda uses,, i now have two one is 5mm the other is 6mm, the 6mm will work with honda touring shields or any that may use a 6 bolt,, if you have a honda touring shield you can raise it to the top holes to gain about a inch, you will need longer bolts,, you can also put in a spacer to move the windshield forward, or change the angle, by putting spacers under the shield or mount, to clear hand guards.
5mm or 6mm plates 25.00 plus shipping dale
