http404
Someone needs to find this Adam Smith and get him to knock it off.What isn’t more expensive these days? Too much money chasing too few resources. Adam Smith and all that.
Hi MZFlorida,I posted somewhere that I purchased this switch and stated that it was a perfect fit. I did purchase it and it will not fit. I hope that i did not cause anyone else to make the same mistake. Pissed off too. I made a beautiful harness, perfectly measured for the fog lights. I think that the right part number for the NC750 is 08V02-MKA-D80. I'm ordering it and will report back. Anyhow, apologies.
The part arrived and I am planning on putting it on this weekend. I don’t want to speak too soon (again) but it looks like a winner. The panels do need to be removed in order to access the screws that hold the cover.Hi MZFlorida,
I would like to do the same thing. Will be very interested to learn if 08V02-MKA-D80 is the right part (if it fits as you suspect) and how you were able to access the location in order to remove the stock blank plastic insert/install the switch. Which light set did you get BTW?
Thank you for the info - much appreciated MZFlorida!The part arrived and I am planning on putting it on this weekend. I don’t want to speak too soon (again) but it looks like a winner. The panels do need to be removed in order to access the screws that hold the cover.
I got these lights https://www.amazon.com/Samlight-Driving-Motorcycle-Wrangler-Tractor/dp/B07H3VBF5Z
and this mount https://www.amazon.com/Off-Road-Mounting-Bracket-360-Degree-Aluminium/dp/B082XKJX83
They’re relatively inexpensive. I like PIAA and Denali but they are insanely priced right now. A trusted contributor recommended these as a product to consider…way more knowledgeable than am I.
If I may, I suggest one of these.I want to mount a momentary switch there and connect it to my garage door opener. That would be the bee's knees.
Sorry I am just reading this thread but my search led me to Partzilla - I'm not sure if it is for the NC but it is worth checking with them if there is interest.I posted somewhere that I purchased this switch and stated that it was a perfect fit. I did purchase it and it will not fit. I hope that i did not cause anyone else to make the same mistake. Pissed off too. I made a beautiful harness, perfectly measured for the fog lights. I think that the right part number for the NC750 is 08V02-MKA-D80. I'm ordering it and will report back. Anyhow, apologies.
I think that is the one for the AT which will not fit without a lot of modification. Here is the AT switch and the EU’s part for the NC750X. The body length is not a huge issue but the distance from the tabs to the mounting point is.Sorry I am just reading this thread but my search led me to Partzilla - I'm not sure if it is for the NC but it is worth checking with them if there is interest.
SWITCH, FOGLIGHT
08V31-MCA-10008.
Honda 08V31-MCA-10008 - SWITCH, FOGLIGHT | Partzilla.com
Buy Honda 08V31-MCA-10008 - SWITCH, FOGLIGHT . This OEM part is guaranteed by Honda's limited part warranty ✓ FREE Shipping on qualified orders - Partzilla.comwww.partzilla.com
Sorry about that Mzflorida, and any others who may have investigated. I was hoping that it was for the NC because when I went to Partzilla "Parts for the NC750" comes up in the search box on top".I think that is the one for the AT which will not fit without a lot of modification. Here is the AT switch and the EU’s part for the NC750X. The body length is not a huge issue but the distance from the tabs to the mounting point is. View attachment 49424
Absolutely no need to apologize! Awesome that you are trying to help out other owners!!!Sorry about that Mzflorida, and any others who may have investigated. I was hoping that it was for the NC because when I went to Partzilla "Parts for the NC750" comes up in the search box on top".
Thank-you for the clarification.
I have something similar, a tiny garage door opener. I just want it integrated because I can, and I lack the good taste and common sense that would stop an ordinary person.If I may, I suggest one of these.
I installed the light switch and it fits like a glove.Hi MZFlorida,
It does have three leads; hot, load, and ground. It illuminates when closed also. I believe they have a Honda fog light harness that goes into the accessory harness. I think Eastern Beaver makes one also. I would have used that option if I did it over again. My installation is neat, but the harness would have been neater, easier and with a predefined cable routing scheme. My fuzeblock is on the right side so I had to define the route, adjust for any potential binding, etc. Not a big deal by any measure but it just would have been very plug and play with the prebuilt harness.MZ, it looks great! I will have to give this a try. I found a wiring harness on Amazon for the lights I found. Hopefully I can trace the switch wiring. The Amazon harness has 3 leads to the switch that it comes with, which is lighted. Does the Honda switch illuminate when the circuit is closed? How many leads are there?
Thanks for your help MZ!
Were you able to obtain the matching connector for the switch? If so what is needed/where to get? (I have the same switch, but will not use the factory fog lights.)It does have three leads; hot, load, and ground. It illuminates when closed also. I believe they have a Honda fog light harness that goes into the accessory harness. I think Eastern Beaver makes one also. I would have used that option if I did it over again. My installation is neat, but the harness would have been neater, easier and with a predefined cable routing scheme. My fuzeblock is on the right side so I had to define the route, adjust for any potential binding, etc. Not a big deal by any measure but it just would have been very plug and play with the prebuilt harness.
Honda connectors are available in many places, but I cut the leads and used waterproof connectors throughout the harness. They are not as tidy as OEM but met my needs. I think they are 4 position or pin .90 sumimoto connectors. Eastern Beaver sells them i think...but so deos Ebay, revzilla, etc.Were you able to obtain the matching connector for the switch? If so what is needed/where to get? (I have the same switch, but will not use the factory fog lights.)
Hi MZ, just got the switch delivered from the UK. Can you share with me the wire color codes or what is best way to figure them out? Sorry, I am not an electrician and thank you.It does have three leads; hot, load, and ground. It illuminates when closed also. I believe they have a Honda fog light harness that goes into the accessory harness. I think Eastern Beaver makes one also. I would have used that option if I did it over again. My installation is neat, but the harness would have been neater, easier and with a predefined cable routing scheme. My fuzeblock is on the right side so I had to define the route, adjust for any potential binding, etc. Not a big deal by any measure but it just would have been very plug and play with the prebuilt harness.
The green is your ground and I ran it to the frame. It's a mechanical single pole switch so line (from your power) and load (to your device) does not matter. But I used the wire that is directly right of the ground in the image in the previous post. I hope this helps. Don't let it intimidate you. @the Ferret put it best when he said we motorcyclists tend to overcomplicate things! I know you did not ask but I thought maybe a basic diagram would help.Hi MZ, just got the switch delivered from the UK. Can you share with me the wire color codes or what is best way to figure them out? Sorry, I am not an electrician and thank you.
