TacomaJD
- Joined
- Apr 30, 2019
- Messages
- 1,561
- Reaction score
- 980
- Points
- 108
- Location
- Northeast Alabama
Anyone ever pulled apart the front brake master cylinder on their bike? My 2013 model front brake lever feels funny and I do not need to encounter a problem with front brakes while on track. It stops good, but almost feels like it has a catch in it. I'm wondering if I may have gotten air in the lines when I done a fluid flush last year, but I'm also wondering if the master cylinder could be failing or dirty. It's not a hard catch, it's difficult to explain. It's like the lever gets hard sometimes and brakes don't grab as good.
I currently have the brakes apart, going to clean the pistons thoroughly, grease the pin, do another fluid flush/bleeding, but I'm also wondering if the oem master cylinder can be taken apart and possibly cleaned, or is it a closed mechanism that you pretty much throw away and replace if needed? I've never messed with master cylinders too much, so this is a bit of a new problem for me.
A new oem master cylinder on Pro Caliber's site is $200......I can get a Brembo master cylinder for $90 more. But I'm not sure what mm the Brembo would have to be to replace the oem one.
Any general info you guys could share would be appreciated.
