How To Lowered Nc750x side/center stands
Denden996
Cowpens SC
My good friend has a 2019 750 with the Lust lowering kit 40mm. He was straining getting it up on the center stand, and the machine stood upright at a unsafe level. I just installed a center stand on my 2021 750. Solution to my friends problem center stand for a 2021 08M70-MKW-D00 and side stand NM4 50530-MJS-305. If you would like the Chrome DCT emblem for the 2021 it's 11378-MKS-E50.
When I lowered my 2012 NC700 the center stand solution was the CTX700 center stand and Soupy's adjustable side stand. It has been working great for years.
I have the Lust 30mm kit so it should lower my NC by 1.2 inches according to their site.
Can you provide some measurements?
What is the length of the 2021 side stand ... footer to center of bolt hole?
What is the length of the 2021 center stand ... center of the axle to the floor between the two feet?
Thanks this will be helpful as this comes up quite a bit but the measurements are hard to find ... its more of "this is what I did" and hard to interpret in another context
Are the parts direct swap or are other modifications to be made to get them in there?
My wife has a SOUPY'S ADJUSTABLE lowering kit installed on her NC...x
After she decided on the correct height, I simply cut the original kickstand, took out about an inch, then welded it back together. Simple job.
Sorry it took so long to respond. Side stand 7 7/8 and center stand 8 13/16 inches.
