I guess I have officially hit my 'farkling limit' (until the next one).
I did my installation of the lights and the Skene controller and it works great. I did not use the Innovv Powerhub that Greg used. I just pulled switched power and ground from other places. I did have some concerns with the mounting of the lights. The bracket that comes with the lights uses a fairly small mounting bolt but the hole in the lamphus clamping mounts is huge. The Lamphus mounts also stick out quite a ways.
Jos.. I have the Givi engine guard - like yours - but my setup ended up sticking out from the guards. If I were to drop the bike, it would land right on the Lamphus mounts ( and the lights). Your pictures seem to have the lights tucked in very nicely. What mounts did you use?
>T
P/S... I just found some Lamphus brand clamping bar mounts that are called 'vertical bar mounts'. It looks like these will mount to the Givi motor guards and keep the lights even with the Givis rather than sticking out 3" on each side. Just placed an order. Will take pics of both and post later.
>T
