Horn and Crash Bar Compatibility
Gazza732
United Kingdom
Hello,
I've got a new Honda NC750X (2019 model) and I'm a beginner so want to check to make sure. I received my Denali Soundbomb Compact yesterday and I have Givi TN1111 crash bars and Denali mounting bracket for the NC750X on their way. My question is will the Soundbomb (via the mounting bracket) and crash bars be compatible as they go on the same area? My thoughts were that I may need to make a workaround using the mounting bracket or something. Advice appreciated.
Thanks in advance.
Hello,
Thanks in advance.
Did you ever find the answer to this?
I ordered the bracket to mount the unit and it looks like the sound bomb is NOT compatible with Givi engine guards.
It is, just. If you use the original Denali mount in the original position, then make another bracket to go on that, it's possible to squeeze it in with about 0.5mm to spare all round it. I used a spare bracket from a Givi top box kit to make it fit.
Welp, I stand corrected! Thank you for letting me know
Might help.
