Tomas
Hello Everyone, I am a happy owner of my 2023 NC750x DCT. Today I decided to clean the front sprocket area, and I did so successfully. After removing all the dirt around, I unfortunately found a bad surprise - some cables are locally damaged from mechanical contact with the chain, perhaps due to an incorrect position. 2 wires are completely cut off.
However, even in this condition the bike behaves flawlessly, including the DCT shifting. I wouldn't recognize any problem at all without removing the plastic cover panel.
I would be happy, if someone experienced could comment on two questions:
Assuming this will not be an easy fix, as a lot of disassembly work might be required. Am I right?
Thank you for any comments.
Tomas
- What's the function of the interrupted cables?
- Is a replacementspare cable available?
Tomas
