Harley-Davidson’s 2021 Pan America Aims to be the Best
Harley-Davidson’s Pan America has been the topic of conversation since its 2020 release. 2021 is no different as they have just released the details on the 2021 Pan America and Pan America Special. It will not be discounted as it holds its own when stacked up to the BMW GS – the ruler of the adventure world.
Harley-Davidson has developed a brand new engine for Pan America – the 1250cc Revolution Max. It produces 150 horsepower @ 9000rpm and 94lb-ft @ 6750rpm. Harley-Davidson scrapped the long-stroke design and went with a short-stroke (oversquare) design for the Revolution Max engine. Its rev limit is twice that of a traditional Milwaukee-Eight and allows it to chase power high into the rev range.
1250 Revolution Max Engine
Harley has truly developed the Pan America to go off-road without skipping a beat. It comprises a steel tubular front, mid, and subframe. These can be changed in the case of a frame-bending spill. Harley has also recessed all drain bolts to shield them from jagged rocks you find on advanced trails. Its “letterbox” headlight is reminiscent of a lightbar found on off-road trucks which assures excellent visibility on or off of the trail. The brake pedal can also be adjusted without tools for standing or seated riding positions.
Harley-Davidson Pan America Ride
The advanced engine, frame, and fancy headlight are just the tip of the iceberg for Harley-Davidson’s revolutionary adventurer. The Pan America comes loaded with tech fit for only the most advanced adventure bikes. It comes fitted with a 6.8-inch full-color touch TFT screen, riding modes, semi-active suspension, tire pressure monitoring, and optional adaptive ride height which automatically lowers the suspension when you stop the bike. Not to mention the basics like cruise control, lean-sensitive traction control, cornering ABS, and hill-hold control.
2021 Pan America Dash
Starting price on the 2021 Harley-Davidson Pan America 1250 will be $17,319 and $19,999 for the Pan America Special which can include anodized aluminum laced tubeless wheels along with the Adjustable Ride Height feature.
Release dates for prospective markets:
North America: May 2021
Europe & Thailand: June 2021
Asia & Latin America: July 2021
China: Sept 2021
Specifications
2021 Harley-Davidson Pan America 12502021 Harley-Davidson Pan America 1250 Special
MSRP:$17,319$19,999
Engine:1,252 DOHC V-twin; 4 valves/cyl.1,252 DOHC V-twin; 4 valves/cyl.
Bore x Stroke:105.0 x 72.0mm105.0 x 72.0mm
Transmission/Final Drive:6-speed / chain6-speed / chain
Claimed Horsepower:150 hp @ 9,000 rpm150 hp @ 9,000 rpm
Claimed Torque:94 lb.-ft. @ 6,750 rpm94 lb.-ft. @ 6,750 rpm
Fuel System:Electronic Sequential Port Fuel InjectionElectronic Sequential Port Fuel Injection
Clutch:Wet, multi-assist, and slip; mechanically actuatedWet, multi-plate assist and slip
Frame:Stressed-member alloy steel trellis; forged aluminum mid-structureStressed-member alloy steel trellis; forged aluminum mid-structure
Front Suspension:47mm inverted fork; compression, rebound, and preload-adjustable, 7.5 in. travel47mm inverted fork, electronically adjustable semi-active damping control, optional Adjustable Ride Height; 7.5 in. travel
Rear Suspension:Piggyback monshock; compression, rebound, and hydraulic preload-adjustable; 7.5 in. travelPiggyback monshock; electronically adjustable semi-active compression and rebound damping control, automatic electronic preload control, optional Adjustable Ride Height; 7.5 in. travel
Front Brake:4-piston monoblock calipers, 320mm disc w/ ABS4-piston monoblock calipers, 320mm disc w/ ABS
Rear Brake:1-single piston caliper, 280mm disc w/ ABS1-single piston caliper, 280mm disc w/ ABS
Wheels, Front/Rear:Cast aluminum 19×3 in. / 17×4.5 in.Cast aluminum standard, anodized aluminum laced tubeless optional; 19 x 3 in. / 17 x 4.5 in.
Tires, Front/Rear:Michelin Scorcher Adventure Radial; 120/70R-19 / 170/60R-17Michelin Scorcher Adventure Radial; 120/70R-19 / 170/60R-17
Rake/Trail:25.0°/6.2 in.25.0°/6.2 in.
Wheelbase:62.2 in.62.2 in.
Ground Clearance:8.3 in.8.3 in.
Seat Height:34.2 in.34.2 in.
Fuel Capacity:5.6 gal.5.6 gal.
Claimed Wet Weight:534 lb.559 lb.
Availability:May 2021May 2021
Contact:harley-davidson.comharley-davidson.com
The post Harley-Davidson’s 2021 Pan America Aims to be the Best appeared first on webBikeWorld.
