skiphunt
Hi,
I'm a new nc700x owner and user on this site. I'm still trying to figure out which windscreen I want to upgrade to, but wanted to share a bit of info I just discovered. I'd recently put some Trackside handguards on my bike to take a bit of the wind of my hands on the highway. In Texas, the temps get really toasty and the wind can feel like a hair dryer on high heat. I also like to take a bit of wind off when it's cooler out.
Anyway, I tried some cheap brush guards that wouldn't mount due to the location of the brake reservoir, so I got the next hand guards up which were the bark-buster style with more adjustments. They mounted fine, but they pointed downward some and I couldn't adjust the angle out of it. A friend tried also and then suggested rolling back the handle bars a bit.
At the same time I'd mounted the hand guards, I'd also moved my stock screen up to the upper mount. At this point I noticed a great deal more turbulence with alternating wind on each side. I'd assumed that it had to do with the new screen position. However, after I rolled my handle bars back about an inch I think, so that the handguards where now parallel with the ground instead of canted downward, the strange turbulence went away. I confirmed this with plenty of riding this weekend.
So, for those of you trying to fine tune your wind deflection... if you have hand guards installed and are getting weird buffeting/turbulence, try checking your hand guard mount angle as well.
