RinconVTR
I will be adjusting my front fork preload soon and wanted to confirm the current spacer size and how much preload is currently there. From the spring free length, the only preload amount is the height of the fork cap. That's it folks.
Because the spring is progressive and a high number of coils are for a soft initial travel, more spacer length will eat up the soft/tightly wound coils and provide a firmer front end. (I've done this on every Honda motorcycle I've ever owned...and strangely...only the Honda's)
Stock spacer out of my bike is 5-7/8" tall.
OD (thin wall tube...ID not worth measuring) This is the max OD for any replacement.
A replacement tube should have an ID of around 1-1/8", but it can be less and not cause any problem.
