Fork oil change
dduelin
North FL USA
Tonight I changed the fluid in the forks and cleaned out the dirty goop that collects in the bottom of the fork legs. Honda does not give a service interval for this that I know of but I tend to keep a bike a long time and regular fluid changes here prolong the wear items of bushings and seals. I do it about every 15 to 20,000 miles with my bikes. There is no drain bolt at the bottom of the fork legs so to drain and replace the fork oil the forks have to come out and drain when turned upside down.
First I supported the front of the bike with a floor jack under the engine crankcase. A piece of wood protects the aluminum sump from the steel jack and spreads the load over a wider area. I lift the front until the rear tire is touching the floor.
Next I removed the front brake caliper by removing the two bolts affixing it to the fork leg. I wrapped the caliper in a clean rag to keep it from scratching it and the paint of the wheel, fender, and fork leg. It hangs from a long bungee cord to keep from stressing the rubber brake hose.
Now I dropped the front wheel out of the fork. Remove the pinch bolt and back out the axle with a 17 mm hex then pull the axle out. Wrap it in a clean rag or paper towel and don't drop the spacers out of the wheel hub and loose them. With the rear tire touching the floor there is enough clearance to roll the tire out from under the fender. The brake disc can be damaged if the wheel falls over on that side. I store it against the wall of the garage.
Next the fender comes off. I didn't get a picture of it but when I removed the bracket that retains the rubber brake hose I could see how easily the bracket could scratch the fender when it's bolt is removed. After removing the 8 mm bolt that retains the bracket I wrapped the hose and bracket in a clean piece of cloth rag. Take out the 5 mm hex head bolts and remove the fender - lift it up at first then turn it 90 degrees to clear the fork legs and not scratch the paint on the fender.
When I turned the fender 90 degrees this little metal spacer fell out and sought the safety of darkness under the air compressor several feet away. I happened to see it as it fell out then lost sight of it. I had a hard time finding it so be careful of this part falling out of the hole or holes in the fender.
The fork tubes will come out next. The fork cap is going to come off to change the oil so loosen the top clamp bolts while the lower clamp bolts keep the fork tube from turning. These are 6 mm allen head bolts and the clearance is tight. I could not use a rachet handle but a breaker bar just fit inside the fairing. I could have removed the fairing to gain more access but I did not.
Now I loosened the fork caps on top of the fork tube while the lower clamp bolts were still in place. Same deal, I want the lower clamp bolts to keep the fork tubes from turning while breaking the fork cap loose with a 17 mm wrench. Be careful of scratching the top of the cap and/or the top bridge of the fork. Just loosen the cap a couple of turns. Don't remove it yet - the spring inside is under pressure.
With the fork leg supported loosen the 14 mm lower clamp bolt. The fork leg will drop out and fall on the floor if you aren't ready for it.
With the tube in one hand and the 17 mm wrench in the other unscrew the fork cap. Turn the last few turns by hand prepared to catch the cap when it springs free. With the stock spring it won't fly off across the room but it can surprise you and fall onto the floor and dent or flatten one edge or muck up the threads on the underside of it.
Pull out the metal spacer on top of the spring.
I tipped the fork tube over so the oil runs out into a catch basin. The spring washer and spring will slide out. Wipe off the spring, washer, and spacer and put in a clean place. Turn the tube upside down and drain out most of the oil by pumping the tube into the leg a few times.
I made a little jig on the edge of the bench to hold fork tubes upside down over a basin. I leave them here for 15 or 20 minutes to drain. The oil is pretty dirty after just 17,250 miles.
While the tubes are draining measure the free length of the springs. There is a spec length of at least 387 mm for stock springs. Mine were 397 mm. Record this over time if you are interested to see if the springs sag. The springs in my ST1300 are original length at 120,000 miles.
After the tubes quit draining I spray a liberal quantity of brake cleaner into the tube and pump the tube into the leg to clean out the goop in the bottom of the legs and fork orifices. Turn the leg and tube upside and pump it dry. Fluid will remain in the fork bottom unless you pump it out. The diluted oil & cleaner that comes out should be clean. I let the forks drain upside down again for a few minutes then place them upright in the jig to completely dry.
I measured about 520 cc of SS-47 Honda fork oil in my beaker. Collapse the tube into the leg and pour in this amount into each fork leg for a total of about 1,040 cc for the entire job. The correct amount of oil will come up to a point 104 mm from the top of the fork tube. This is supposed to be 514 cc per leg but I pour in a little excess. If you prefer another brand of oil be advised that "weight" is not a good method to describe the qualities of light oils like this. A 5 wt oil in one brand can be thicker than the 10 wt oil in another brand but use what oil you like. I prefer to stay with the stock oil at least for a change or two. SS-47 is described as a 10wt oil by Honda so you could use Honda SS-8 which is another Honda 10wt oil.
I made a fork oil gauge with a syringe and a piece of vinyl tubing. The distance from the bottom of the syringe barrel to the tip of the tubing is 104 mm. I place the barrel against the top edge of the fork tube and suck out excess oil until it pulls air leaving a stock oil level of 104 mm.
Insert the spring with the tightly wound coils downward then the washer then the spacer. With the fork cap in place and held down with the palm of my right hand I turn the fork tube with my left hand to start the threads. Finish tightening the cap with the 17 mm wrench until you can turn no further. Insert the reassembled fork tube into the lower fork clamp until the top edge of the tube is flush with the top bridge and tighten the lower clamp bolt to hold in in place. Torque the lower clamp bolt to 29 ft. lbs. then tighten the fork cap to 16 ft. lbs. Only after the lower bolt and the fork cap are tightened did I torque the upper clamp allen bolt to 16 ft lbs. Repeat with the other leg. Reassemble the brake caliper to the fork leg. The caliper slips over the brake disc easy if you spread the pads apart before slipping it into place. Torque the caliper mounting bolts to 22 lbs. Honda says to replace them every time but I reuse them once or twice. Replace the fender and wheel to complete the job. The axle torque is 55 ft lbs, the axle pinch bolt 16 ft. lbs. Apply front brake until the pads contact the disc before riding the bike.
Great write up, Dave.
If so inclined, a body doing this job could fairly easily install Racetech Gold Valve Emulators at the same time. The added tasks would be to remove the one bolt at the bottom of each fork leg, dump out the damper rods and drill some additional holes. Reinstall the rods. Assemble and adjust the emulator valves and drop them on top of the damper rods. Shorten the spring spacers by about a half inch (or whatver is the thickness of the emulator valves). Reassemble the rest as described by Dave.
Greg
L.B.S.
Fixed Idea
Vancouver BC Canada
I :heart: the dduelin pictorial step by steps :D
This had me cracking up LOL: "...little metal spacer fell out and sought the safety of darkness under the air compressor..."
JDE
Central Valley, California
nc700-forum.com
Cool write up!! Thank you for posting this. I'm coming up on 12k miles myself and have been wondering about when to do this and how. I've never performed this task before. I was also planning on when I did do this (if I decide to tackle it myself) to put in the Race Tech Gold valves as well. Might as well while I've got it all apart you know.
Beemerphile
#1 Elite
Danielsville, GA
Nice technique and write-up Dave. You are a meticulous mechanic - cleanliness, care, and use of proper torques. An amateur mechanic marks his work by the damage he does to the parts of the bike. You will never see evidence that the good mechanic was ever there.
RE: RaceTech. They will suggest that you use their RT springs with the emulators. I understand that everyone is selling their own product, and that may or may not be the reason for their recommendation, but they state that stock springs are selected to work with the limitations of the stock dampers. RT springs are single rate (vs. the dual rate stock springs) and normally stronger than stock springs. RT's logic there is that it is easier to tune with single rate springs and that progressiveness in the suspension with their approach is accomplished by adjusting the fill level. Air (above the oil) compressed by the fork action gives progressive rate to the system. They also will provide a recommendation for different oil weight and fill level. If you accept their systems approach, in addition to adding the emulators and drilling out the control orifices in the damper rods, it includes springs, a different spec and quantity of fork oil, and spacers designed for a specific preload on the springs. There are also some set-up specs for the adjustments on the emulators. Mine were set up by RT and I found them to be both firmer and more compliant - a combination that seems impossible. I don't disagree with doing the RT conversion at the same time. It makes perfect sense, however if going that route, I would use the complete RT prescription.
All of this is RaceTech talking. I don't pretend to know anything about tuning a front suspension, so I left it all in their hands. I believe that I have posted the spring, spacer, and oil specs in one of my rambling threads on the subject.
duk2n
Spain
If RaceTech had a good dealer over here (one that works for a live, and not one that sells the RT stuff for the same money it would cost me to import it individually and directly), I would upgrade at least the front fork inmediatelly. I envy you guys.
dduelin
North FL USA
Some notes to add:
The lower fork clamp is carbon steel and there was quite a bit of surface corrosion staining (rust stains) on the fork tubes where the lower clamp surrounded them. I used a bit Fine bronze wool and WD40 to remove the rust stains and polish the surfaces clean again. The wool won't scratch the chrome but removes the rust stains. I would want to do this at least yearly where I live to prevent rust getting through the chrome and pitting the tubes under the clamp.
Honda recommends the 2 caliper retaining bolts be replaced with new ones every time they are removed. It is a special ALOC bolt with a removable thread locker compound on the threads. The color of the removable Honda compound is red. I mentioned I will reuse these once or twice before replacing with new. Before reassembly I clean the threads and apply a dot of blue LocTite thread locker. Blue Loctite is removable - Red LocTite is not easily removed.
I rode the bike about 300 miles the next day, yesterday. I know the original fluid was not degraded much at 17,250 miles but the new fluid seemed to soften the harsh high speed damping the NC700X has over large or repeated sharp-edged bumps. Maybe it was just a placebo effect but it still felt better.
dramd
OR
Some notes to add:
I was asking about this in the off-road thread. You just confirmed my worries about rust on that lower clamp. Thanks for the info on how to clean it up. Will leaving the WD40 on to prevent corrosion create any safety issues?
JDE
nc700-forum.com
I'm getting really close to doing this now. Got about 17.5k miles miles and the are going by very quickly now that the riding season is in full swing for me. At 100mi a day commuting I'm begining to feel like it's time to do this. I also am thinking about getting Race Tech springs and Gold Valves when I do this. Couple questions though. Did you have to, or even did you replace the seals for the forks at the same time? Is there a general mileage/time frame to proactively change them out or just wait until they fail? Trying to figure out what other tools and parts I may need to purchase before tackling this job.
I would replace the seals only when they fail. You can change oil, install the RaceTech parts, and drill the damper rod without ever touching the seals or separating the inner and outer fork tubes.
JDE
nc700-forum.com
Cool, thanks for the reply 670cc! Now I just need to call Race Tech tomorrow and see which springs and oil they recommend for my weight and ride I'm looking for.
Sent from my SM-G900V using Tapatalk
Cyclerosis
Eastern Panhandle WV
Super tech write up! Thanks for taking the time to put the procedure in writing. I'd just like to mention though, the axle is a 17mm hex instead of 27mm.
ray
Singapore
Thanks for the efforts in writing up :thumb:
I would like to check if using brake cleaner to clean the inside of the fork is generally acceptable. I did not remove the bottom bolt to release the fork piston, which I believed some old oil got stuck inside. Ended up the new oil was a little mulky after filling up as it was mixed with some old oil and junk at the bottom of the fork.
