Engine light on (and flashing) and exhaust/engine run off beat.
Mendy
Melbourne, Australia
I have a 2012 nc700sa. The last few days, the engine light has come on, and when it does, the engine runs differently, and the exhaust backfires and pops more aggressively, in an unhealthy sounding way.
Today I got 8 long, and 5 shorts engine light flashes.
I am due for a serve anyway, so will get the mechanic to look over, but I've heard a loose battery and /or angle sensor can show codes easily.
But that doesn't explain the engine running differently does it? Anything I should check at home meanwhile, until I get it to my local mechanic. Locates in Australia, if that helps.
Thanks in advance.
No 8-5 code in the manual.
8-1 and 8-2 are TP sensor errors
Has you mentioned:
86-1 is dash data line communication issue …….common with battery low and loose battery connections.
