Spaceteach
I was thinking about ordering some JIS screwdriver bits yesterday and when I did a google search I was only able to find I vendor with bits. There were plenty with screwdrivers and sets, but my impact driver requires the insert bits. I did however find a post about modifying a Phillips bit to work on JIS screws, and thought I'd share it with the forum. Here are the instructions he posted.
Take a regular number 2 Phillips head screwdriver bit and grind a little at a time off the pointy end until it fits flush in a JIS screw head without rocking or moving back and forth. I tried it and it seems to work. I used a cutoff wheel on my Dremel Tool and cut about a sixteenth of an inch off the end of a new bit. When I tried it on a JIS screw, it fit like a champ. I haven't used the bit much so far, but early indications are looking good.
I realize this is not an actual JIS bit, but it's worked for me on everything I've tried. At any rate, if you like the idea give it a try and please reply with you findings.
Bob
Bob
