kjang
Can some one explain the what is combined anti lock brakes compared to regular anti lock brakes ?
Thanks,.
Ken
Thanks,.
Ken
Some help here from one of you dirt bike riders. I am not suppose to hit my front brake in the dirt? If I hit my front brake in the dirt, I go down. How, you tell me if I hit my back break, I am also hitting my front brake. That sounds like linked braking, not ABS anti lock breaking.
This is what Honda says about the brakes: "The brakes are linked rear-to-front and incorporate an Anti-lock feature (C-ABS) for excellent stopping power, especially under challenging conditions."
I must be missing something here. If I hit the front brake in the dirt, I am going down in the dirt. If I hit the back brake, I am also hitting the front brake , and I am going down in the dirt. And if I am going down this rocky pass, when I hit either brakes with ABS they are not going to lock up, only going somewhat slower down the rocky pass, and I am going down again.
Don't sound like a dirt bike rider should want to hit any of these brakes, or down he goes. In the dirt don't sound like I would want those ABS brakes. But I guess it really doesn't matter, because I usually go down anyway.
The rear brake operates ONE of the THREE pistons on the front caliper. The system uses some proportional valving system so that under light pressure on the rear brake only a very light pressure is applied to the front. The pressures aren't the same. Harder applications of the rear brake result in an increase of the proportion of power also applied to the front. That is: the proportion of front/back pressure applied increases....the relative power increases, not just the absolute power. What that boils down to is that under normal riding conditions the linked effect is so light that you'll probably not even notice it.
Yes .....................Mike Cash- so if I used the rear brake (foot brake) it will apply a certain amount of pressure to the front brake depending on how much pressure I use. The more pressure on the foot brake, the more pressure is applied to both rear and front brake. So if I only use the front brake then it only activate the front brakes.
did I get this right ? I'm just trying to understand on how this combined antilock brakes work.
Ken
I dont have ABS on my Nc700, but for those of you who do have it, can you NOT turn it off or disable it. I could on my bmw g650gs, simple hold down a button and the abs was deactivated. If you can deactivate it, doesnt this also deactive the linked braking?
simple Explanation
see this article for a simple as possible Explanation of braking systems: Road Science: Braking Part 4
Conclusion: The Rider: Still the Most Important Component
