TacomaJD
- Joined
- Apr 30, 2019
- Messages
- 1,561
- Reaction score
- 1,012
- Points
- 108
- Location
- Northeast Alabama
Well. Changed oil, filter, and DCT filter the other night. Not my first time doing this, but first time doing this in this particular bike. That night, after changing oil, I crank it up on center stand and shifted into first gear, let it idle a bit, back to neutral, and cut it off. Today, I was gonna ride it down the road and back. Crank it up and the check engine light came on and wouldn't go off. Running just as normal as can be. Rode it down the road, shifts fine, runs fine, just like normal.
I need to know how to check the code it's throwing. I read on here something about riding it, then stopping, putting in neutral, then putting sidestand down and the check engine light should blink to give the code....well I tried that and the light just stays illuminated, doesn't blink at all no matter what you do.
It's a 2016 NC700X. I'd imagine it has the oem battery, so maybe that's it, throwing low voltage? It starts quickly just like normal, so maybe not.
Any advice or direction is very much appreciated.
