That looks like the wrong stand for the bike. The correct one works perfectly and isn't all that expensive.View attachment 45945View attachment 45946
I used a old dirt bike mirror mount with a threaded bold in the end. Drilled CS, put bolt in it so it won’t rotate. Put some thick electrical tape over bolt head for the bumped stop. Didn’t want to take off aftermarket muffler. Job done…2021 model.
Hmmmm I bought what I think or was suppose to be for the 2021 DCT and the directions on the Honda manual says loosen the stock muffler and insert a screw to hold the spring up. No threaded hole that we can find. May just end up drilling a hole in the stock muffler bracket and attach the spring thru the hole. Can't be that difficult.It fits perfectly but designed to stop on the stock exhaust. I have a aftermarket pipe on it that doesn’t have a stop built into it like the stock exhaust. I might just put the heavy stocker back on it but this thing sounds great right now.
It is not real obvious to find the threaded hole. I would look again before drilling.Hmmmm I bought what I think or was suppose to be for the 2021 DCT and the directions on the Honda manual says loosen the stock muffler and insert a screw to hold the spring up. No threaded hole that we can find. May just end up drilling a hole in the stock muffler bracket and attach the spring thru the hole. Can't be that difficult.
Good to have the threaded hole confirmed...THANKS!!It is not real obvious to find the threaded hole. I would look again before drilling.
