firefoxfire
Hi,
I’m new and I was reluctant to make a post about my problem connecting some auxiliary lights to my 2019 NC750X, but I can’t seem to figure it out.
I have a few questions and hopefully I’ll get a solution but will see! I searched the forum for the same problem but couldn’t find a thread with the same question.
1: I’m trying to connect some Puig LED Auxiliary lights with a pretty straight forward manual, my only problem is the key line that needs to be connected to a “life” wire when the bike is on. I don’t want to cut in wires to make this work so I was thinking about a Fuzeblock or Thunderbox to connect the key line to, will this work to resemble a life wire?
2: I already have a tickle charger connected to my battery with a fuse, I wanted to double tap with the auxiliary lights, but the FB or TB also needs to bo connected to the battery. Is it possible to connect 3 accessory to the battery (2 with fuses)? Or do I need to strip the cables of the light to put in the FB or TB
3: Is it necessary to buy the subharnass + relay to connect the lights or other accessory’s?
4: If I want to add more accessory’s can I connect them to the FB or TB without using the battery connectors?
I added the diagram and picture of the keyline.
Help is greatly appreciated!
