The 2022 BMW F 900 R: A Refined Naked Middleweight
The BMW F 900 R is a dynamic European naked bike competing in the middleweight arena against many competitors. The high-torque two-cylinder in-line engine of the F 900 R delivers 64 lbs-ft of torque between 4,500 and 8,500 rpm. Just the right speed range to get the most fun out of the power.
As found on other models within the 2022 BMW lineup, Rain/Road modes, a bright TFT display, ABS, and ASC (stability control) are standard, but BMW offers excellent upgrades as part of the premium package. Dynamic ESA electronically adjustable suspension, Ride Mode Pro, Gear Shift Assist Pro, and much much more are all part of the $2500 upgrade, a very worthwhile addition.
BMW does an excellent job of the ergonomics of the F 900 R, which can be equipped to fit you perfectly. Standard adjustable hand levers, several available seat heights, and handlebar positions make it very simple to find your perfect fit in the saddle.
3 Color choices for the 2022 BMW F 900 R: Light White, Style Sport, Style Triple Black
The 2022 BMW F 900 R starts at $8,995 USD / $10,495 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW F 900 R in one place.
- Price: $8,995 USD / $10,495 CAD
- Adjustable hand brake and clutch levers
- ASC
- LED headlight (low / high beam)
- LED indicators
- Riding modes Rain/Road
- 6.5” TFT display with BMW Motorrad Connectivity
- Engine: 895cc Parallel Twin
- Power: 99 hp at 8,500 rpm
- Torque: 68 lb-ft at 6,750 rpm
- Wet Weight: 465 lbs (211 kg)
- Seat Height: 32.0″ (820 mm)
- Yamaha MT-09
- KTM 890 Duke R
- Triumph Street Triple RS
2022 BMW F 900 R Specifications
Engine | 895cc, Water-cooled 4-stroke in-line two-cylinder engine, four valves per cylinder, two overhead camshafts, dry sump lubrication |
Engine Power | 99 hp at 8,500 rpm |
Bore x Stroke | 3.4” x 3.0” |
Compression Ratio | 13.1 : 1 |
Fuel delivery | Electronic fuel injection |
Max Torque | 67 lb-ft at 6,500 rpm |
Clutch | Multiple-disc wet clutch (anti hopping), mechanically operated |
Transmission | Constant mesh 6-speed gearbox integrated in crankcase |
Drive | Endless O-ring chain with shock damping in rear wheel hub |
Suspension Front | Upside-down telescopic fork, Ø 1.7″ |
Suspension Rear | Cast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable |
Brakes Front | Dual disc brake, floating brake discs, Ø 320 mm, 4-piston radial brake calipers |
Brakes Rear | Single disc brake, Ø 265 mm, single-piston floating caliper |
Tires Front | 120/70 ZR 17 |
Tires Rear | 180/55 ZR 17 |
Fuel Tank Capacity | 3.4 gal (13 L) |
Color | Sport, Black Storm Metallic, Exclusive |
Alternator | Permanent magnetic alternator 416 W (nominal power) |
Battery | 12 V / 12 Ah |
Headlight | |
Tail Light | LED Tail Light |
Overall Length | 84.2″ (2,140 mm) |
Overall Width | 32″ (815 mm) |
Overall Height | 44.4″ (1,130 mm) |
Wheelbase | 59.7″ (1,518 mm) |
Castor | 4.5″ (114.3 mm) |
Seat Height | 32″ (OE suspension lowering kit: 30.3″, OE low seat: 31.1″, OA high seat: 32.8″, OA comfort seat: 33″, OE extra high seat: 34″) |
Unladen weight, road ready, fully fueled | 465 lbs (211 kg) |
Warranty | |
Extension |
2022 BMW F 900 R Features
High-torque engine.
More torque, more riding enjoyment. Life can be that simple.Agile chassis
.Sporty, intuitive, precise: is there any better feeling than being one with your machine?
Adaptive headlight.
One of a kind among the roadster class: steer into the light when turning into a curve.Short exhaust.
Striking and crisp: for an expressive appearance.Dynamic ESA.
Electronically adjustable suspension is a hard thing to find – but you’ll find it with us.TFT dashboard with Connectivity.
The 6.5“ TFT colour display and BMW Motorrad Connectivity. Connect your smartphone with your F 900 R via Bluetooth. The 6.5 inch TFT display will now show you all information relevant to your ride and also offers additional features like navigation, music and telephony.Gear Shift Assist Pro.
You can switch gears without touching the clutch, keeping the tractive force smooth to give you more dynamism as well as more comfort as it keeps your clutch hand free.Variety of seat heights.
Six seat heights from 30 to 34 inches: all riders will find the right height and secure footing for them.2022 BMW F 900 R Photos
2022 BMW F 900 R Videos
The 2022 BMW F900R!! • 1st Service & Test Ride!
Can BMW F 900 R tempt me away from KTM and Triumph?
BMW Official Websites
The post 2022 BMW F 900 R [Specs, Features, Photos] appeared first on webBikeWorld.
