- Joined
- Jun 19, 2015
- Messages
- 1,522
- Reaction score
- 474
- Points
- 83
- Location
- Surrey, BC (Canada)
Thanks for the post. Had never seen it used before.You decide:
That’s a slick tool, but I don’t see how it’s any more accurate or any quicker than using a simple ruler. That tool is not something I’d want to pack on a trip, either.You decide:
You decide:
I’ve lived long enough with NCs that when I can lift the chain and just about touch the underside of the swing arm with it - that’s about 45 mm when measured on the center stand. I like to keep it between 35 to 45 - measured on the center stand - so it’s time to loosen the axle nut and adjuster lock nuts, wedge the plastic handle of an old screwdriver I use expressly for this between the lower chain run and the sprocket, and turn the adjustment nuts 180 degrees, tighten everything up. The caternary will be about 35 mm. I have a Motion Pro alignment tool but I don’t use it every time as my method adjusts each side equally.You decide:
But did you forget to pick up a gallon of SAE Blinker Fluid? I didn't see that on you list.Picked up some parts at the store for coming maintenance. Will be a biggie. Front tire, valve check, oil change, air filter and fork oil.
Also worked on my rain gear repair. Before showing seam that is no longer heat sealed.
After prep and application. Used a bamboo kabob stick as an applicator. Glue is kind of thick and stringy. Cleaned surface with alcohol. Says it takes 8-12 hours to cure. We will see in the morning. We get enough rain here so the sealing power will definitely get tested.
I got hammered on the ctx700 forum for suggestion this to someone who was having similiar issue.....received replies by many that if the clutch(s) are not replaced, not to do the clutch init procedure.....sorry for their loss, I dont go to the site anymore....Update on the clutch init I did a few days ago : Absolutely worth it. If you haven't done it, give it a try.
Did my usual week-end trip across the Santa Monica mountains. Gear shifts are smoother and do not upset the bike as much as they used to. Oddly, I think some downshifts seem to take a fraction longer to feel the rev up of the engine. I'll keep an eye/ear/butt_cheek on it, because it clicks (fainter than before), so it should be in gear.
Also, after the Santa Ana winds, the views from the top of Malibu were amazing, towards the islands and mountains 40+ miles away, but especially where the smog usually sits over LA and San Fernando. Millions of people were breathing better than usual. I need to stop being late, so I can pause for pictures.
If periodic clutch initialization is a worthwhile task, it’s too bad Honda didn’t make this an automatic process that happens behind the scenes without operator intervention. The DCT in my Ford car has never required such an initialization since the clutch was last replaced 40,000 miles ago.Update on the clutch init I did a few days ago : Absolutely worth it. If you haven't done it, give it a try.
