2021 Indian Chieftain [Model Overview]
Canada Eh!
The All-New 2021 Indian Chieftain​
The Indian Chieftain is the jewel in the crown of the 2021 Indian motorcycle line-up. It’s big, powerful, and the perfect fit for anyone wanting a truly authentic American motorcycle experience. It’s got the full-fairings, the bags, and the muscle, that these iconic V-twin cruisers are famous for.
There are two engine options for the 2021 Chieftain: 1,811 cc (111 cu in) and 1,890 cc (116 cu in). Both offer enormous power, with the torque output starting from 119 lb-ft. That power is delivered through a silky smooth 6-speed transmission for comfortable long-distance riding.
Comfortable mile-munching is easy on the Chieftain since it comes equipped with a comprehensive RideCommand infotainment system, cruise control, ABS, and soft rogue seat as standard.
For 2021, the Indian Chieftain is available with different color schemes to match the engine options. The smaller 1,811 cc model is available in Thunder Black, while the larger 1,890 cc model is available exclusively in Titanium Smoke.
The 2021 Indian Chieftain starts at $21,999 USD / $26,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Chieftain in one place.
Motorcycle Overview​
  • Price: $21,999 USD / $26,999 CAD
    • Two Thunderstroke V-twin engine options
    • Advanced RideCommand infotainment
    • ABS
    • Cruise control as standard
  • Engine type: 1,811 cc/ 1,890 Thunderstroke V-twin
  • Horsepower: 78 HP (estimated)
  • Torque: 119 lb-ft/ 126 lb-ft
  • Wet Weight: 821 lbs (372 kg)
  • Seat Height: 25.6 in (650 mm)
2021 Indian Chieftain Specifications​
ENGINE
Engine1,811 cc, Thunderstroke ®111
Engine Power
Bore x Stroke3.976 in x 4.449 in (101 mm x 113 mm)
Compression Ratio9.5:1
Fuel SystemClosed loop fuel injection / 54 mm bore
ExhaustSplit Dual Exhaust w/ Cross-over
DRIVETRAIN
ClutchWet, Multi-Plate
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearSingle Shock w/ Air adjust
Brakes FrontDual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes RearSingle / 300 mm Floating Rotor / 2 Piston Caliper
Tires FrontDunlop® American Elite 130/60B19 61H
Tires RearDunlop® Elite 3 Multi-Compound 180/60R16 80H
Fuel Tank Capacity5.5 gal (20.8 L)
Color / GraphicsThunder Black
ELECTRICAL
Ignition
HeadlightHalogen Headlamp
Tail LightLED Taillight
DIMENSIONS
Overall Length98.7 in (2,506 mm)
Overall Width39.4 in (1,000 mm)
Overall Height54.5 in (1385 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.1 in (130 mm)
Seat Height25.6 in (649 mm)
Weight (Empty Tank / Full of Fuel)789 lbs / 821 lbs (358 kg / 372 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Chieftain Features​
TWO THUNDERSTROKE V-TWIN OPTIONS
Choose the new, more powerful Thunderstroke 116 engine producing 126 ft-lbs of torque or the exceptional Thunderstroke 111 for power at low RPM and a responsive ride at any speed.
AGILE HANDLING AND CONTROL
Outstanding steering geometry and a lightweight cast aluminum frame come together to provide responsive handling and agile cornering.
CORNER CARVING CONFIDENCE
A strong, expertly designed cast aluminum frame gives you confidence-inspiring stability and easy handling at all speeds.
STYLING THAT HAS AN EDGE
With sleek fairing and slammed saddlebags this bike looks as aggressive at it rides.
ROGUE SEAT
The Chieftain’s streamlined profile is enhanced by a gunfighter style seat.
MODERN. MEAN.
The custom-inspired look is completed by a 19″ front wheel, open fender and badging.
PREMIUM AUDIO
Hear every note with high-output speakers in the fairing that deliver 100-watts of crystal-clear audio. And the dynamic equalizer automatically adjusts for road, wind, and engine noise.
A HIGHER STANDARD
The Chieftain comes standard with keyless ignition, cruise control, and ABS.
PUSH-BUTTON POWER WINDSHIELD
A push-button power windshield allows you to easily change the feel of your ride. Low lets the wind rush the senses, high keeps you shielded and comfortable.
2021 Indian Chieftain Photos​
2021 Indian Chieftain Videos
The post 2021 Indian Chieftain [Model Overview] appeared first on webBikeWorld.
