2021 Ducati Diavel 1260 [Model Overview]
Ducati’s Premier Muscle Cruiser: The Diavel 1260​
Ducati’s muscular power cruiser is one of the most exciting models in the 2021 Ducati line-up. Featuring all of the classic hallmarks of a genuine Ducati motorcycle, the Diavel includes elegant bodywork, a commanding road presence, and an exotic Testastretta DVT twin-cylinder engine with a fiery temperament. This is what a cruiser looks like when made by an Italian manufacturer.
This class-leading cruiser draws power from Ducati’s muscular 1,262 cc Testastretta DVT 1262 twin-cylinder engine, producing 159 horsepower and 95 lb-ft of peak torque. It’s a powerful cruiser, and to keep that power in check, Ducati has treated the Diavel with a full suite of impressive riding aids.
The most significant of these include a sophisticated ride-by-wire system, three selectable riding modes, three power modes, traction control, wheelie control, cornering ABS, and more. Other plush features include Desmodromic variable valve timing, a full LED lighting system, and a gorgeous two-tailpipe exhaust.
Naturally, riders looking for more can enjoy access from Ducati’s extensive accessory catalog for extensive personalization options.
For 2021, the Diavel 1260 is only available in Dark Stealth black with Sandstone Grey accents.
The 2021 Ducati Diavel 1260 starts at $20,295 USD / $23,695 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Ducati Diavel 1260 in one place.
  • Price: $20,295 USD / $23,695 CAD
    • 157 HP Testastretta DVT 1262 engine
    • Selectable riding modes and power modes
    • Cornering ABS
Main Specs​
  • Engine: 1,262 cc liquid-cooled, Testastretta DVT V2 engine
  • Power: 159 HP
  • Torque: 95 lbs-ft
  • Wet Weight: 514 lbs (233 kg)
  • Seat Height: 30.7 in (780 mm)
Competitors​
2021 Ducati Diavel 1260 Specifications​
Engine1,262 cc liquid-cooled, Testastretta DVT V2 engine
Power159 HP
Bore x Stroke106 mm x 71.5 mm
Compression Ratio13.0:1
Fuel SystemBosch electronic fuel injection system, Øeq 56 mm elliptical throttle bodies with Ride-by-Wire system.
ExhaustStainless steel muffler, catalytic converter and 2 lambda probes
ClutchSlipper and self-servo wet multiplate clutch with hydraulic control
Transmission6 Speed
Final DriveChain, Front sprocket Z15, Rear sprocket Z43
Suspension Front Ø 50 mm adjustable Marzocchi fork
Suspension RearMonoshock, preload and rebound adjustable, Aluminum casted single-sided swingarm
Brakes Front2 x Ø 320 mm semi-floating discs, Radially mounted Brembo monobloc 4-piston M4.32 callipers, PR18/19 radial master cylinder, Bosch Cornering ABS Evo
Brakes RearØ 265 mm disc, Brembo 2-piston floating calliper, Cornering ABS
Tires FrontPirelli Diablo Rosso III 120/70 ZR17
Tires Rear
Pirelli Diablo Rosso III 240/45 ZR17
Fuel Tank Capacity17 l (4.5 US Gal)**** 16 l (4.2 US Gal) for US/Canada/Mexico version
ColorDark Stealth
Ignition
HeadlightLED
Overall Length
Overall Width
Height
Wheelbase1,600 mm (63.0 in)
Trail120 mm (4.7 in)
Seat Height780 mm (30.7 in)
Dry Weight221 kg (487 lb)
Warranty24 months unlimited mileage
2021 Ducati Diavel 1260 Features​
Design​
A contemporary character
Muscular lines and an imposing front bring out the strong and restless personality of the new Diavel, featuring a long, slender rear with a 240 mm rear wheel. The color range of the Diavel 1260 has been updated: the standard version is now available in total black, while the S version is available in Ducati red with white graphics. A new sporty Diavel 1260 S, without sacrificing the style that distinguishes it.
Engine​
The engine is the king
The new Diavel is built around the Testastretta DVT 1262 engine, a beacon of power, beauty, and sophistication. Its 157 hp translate to unbelievable acceleration and pick-up, while the flat and consistent torque curve low rpm allows steady and easy to handle delivery. The Ride by Wire (RbW) control matched with three Riding Modes and three Power Modes allows personalized engine responsiveness. A true beauty, as far as mechanics and design go, and a real game-changer on the road.
Ergonomics​
Riding pleasure at its best
Sportiness and comfort meet in the new Diavel. The trellis frame ensures lightness and torsional rigidity, while the adjustable fork provides comfort and stability. The care devoted to ergonomics is complemented by the perfect combination of a higher handlebar, a lower seat and central footpegs, with a comfortable and versatile riding position. The S version is fitted with Öhlins suspensions, for a guaranteed fun and exciting riding experience.
2021 Ducati Diavel 1260 Photos​
2021 Ducati Diavel 1260 Videos​
The post 2021 Ducati Diavel 1260 [Model Overview] appeared first on webBikeWorld.
