The 2021 Can-Am Ryker Offers Affordable Fun On Three Wheels
The Can-Am Ryker is an entry-level three-wheeled trike from Canadian manufacturer Bombardier Recreational Products and their sub-brand Can-Am Motorcycles. This low-cost machine is one of the most exciting models in the 2021 Can-Am line-up. It’s affordable, powerful, and tremendous amounts of fun. What’s more, it’s versatile and highly customizable, with a configuration and displacement to suit almost any rider. For 2021, the Can-Am Ryker is available with two engine options:
The European-made Rotax ACE 600cc engine is a fuel-injected, in-line two-cylinder powerplant that produces 50 horsepower and 36.7 lb-ft of torque. It is a powerful but manageable engine that’s ideal for entry-level riders.
The Rotax ACE 900cc engine option is a fuel-injected triple-cylinder beast. It offers superior performance to the smaller engine, with 82 horsepower and 58.5 lb-ft of torque on tap. For riders who opt for the 900 cc engine, there are two selectable rider modes included: Eco and Sport. The Sport mode is ideal for those who enjoy drifting…
No matter what engine you choose, automatic CVT transmission comes as standard, offering easy twist-and-go riding, and an uncomplicated ride experience. In fact, “uncomplicated” is the buzzword here. The Ryker also features a low-maintenance experience thanks to the use of a drive shaft, and tool-free adjustability to allow for easy customization.
Other awesome features for this unique three-wheeler include traction control, ABS, a D.E.S.S (Digitally Encoded Security System) anti-theft system, and hill hold control.
For 2021, the Can-Am Ryker is available in over 22 different color options.
The 2021 Can-Am Ryker starts at $8,799 USD / $11,099 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Can-Am Ryker in one place.
Motorcycle Overview
- Price: $8,799 USD / $11,099 CAD
- Two available engine options: 600cc or 900cc
- Twist and go CVT transmission
- Over 100,000 possible configurations
- Advanced VSS (Vehicle Stability System)
- Engine type: 600cc / 900cc Rotax ACE engine
- Horsepower: 50 HP / 82 HP
- Torque: 36.7 lb-ft / 58.3 lb-ft
- Dry Weight: 594 lbs (270 kg) / 616 lbs (280 kg) **Wet weight info unavailable
- Seat Height: 23.6 in (599mm) / 23.5 in (597mm)
2021 Can-Am Ryker Specifications
Engine | |
Engine displacement | 600 cc ROTAX 600 ACE / 900 cc ROTAX 900 ACE |
Type | Rotax® 600 ACE Rotax® 900 ACE |
Bore & stroke | 2.9 x 2.7 in. (74 x 69.7 mm) |
Power | Ryker with 600 engine: 50 hp (37.3 kW) @ 7300 RPM Ryker with 900 engine: 82 hp (61.1 kW) @ 8000 RPM |
Torque | Ryker with 600 engine: 36.7 ft-lb (49.7 Nm) @ 6000 RPM Ryker with 900 engine: 58.3 ft-lb (79.1 Nm) @ 6500 RPM |
Lubrication | |
Drivetrain | |
Transmission | Automatic (CVT) with reverse function |
Clutch | |
Final Drive | |
Chassis | |
Suspension Front | Double wishbone |
Suspension Rear | Multi-link – mono swing arm |
Brakes Front | 270 mm discs with Nissin 2-piston floating calipers |
Brakes Rear | 220 mm disc, 1-piston floating caliper |
Tires Front | MC 145/60R16 66T |
Tires Rear | MC 205/45R16 77T |
Fuel Tank Capacity | 5.28 gal (20 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | Digitally Encoded Security System (D.E.S.S. |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 92.6 x 59.4 x 41.8 in. (2,352 x 1,509 x 1,062 mm) |
Wheelbase | 67.3 in. (1,709 mm) |
Seat height | Ryker with 600 engine: 23.6 in. (599 mm) Ryker with 900 engine: 23.5 in. (597 mm) |
Ground clearance | Ryker with 600 engine: 4.1 in. (104 mm) Ryker with 900 engine: 4.0 in. (102 mm) |
Dry weight | Ryker with 600 engine: 594 lb (270 kg) Ryker with 900 engine: 616 lb (280 kg) |
Curb Weight | |
Warranty | |
Warranty | 1-year BRP Limited Warranty with 1-year roadside assistance |
Extension | B.E.S.T. terms available from 12 to 36 months with roadside assistance |
2021 Can-Am Ryker Features
Features
2 halogen headlamps (55 W)
Front fenders with integrated LED lights
Dual USB port
Glove box
Adaptive foam waterproof seat
2021 Can-Am Ryker Photos
2021 Can-Am Ryker Videos
Can-Am Websites
The post 2021 Can-Am Ryker [Model Overview] appeared first on webBikeWorld.
