The BMW’s Versatile and Fun-Filled F 900 R Roadster
The F 900 R is a dynamic roadster designed for a blend of performance and practicality. It’s a fun-loving European-made machine that has none of the dull and dreary character of its predecessor, the F 800 R. While the F 800 R was designed for performing a basic function, the F 900 R is all about the ride experience. Whether you’re commuting, cruising, touring, or leaning into corners, the F 900 R will put a smile on your face. It’s the unexpected jewel in the 2021 BMW line-up.
The F 900 R draws power from a compact 865cc parallel-twin engine, and produces 99 horsepower, 67 lb-ft of torque, delivering top speeds of over 124 mph. That power is transferred to the rear wheel via a six-speed transmission and kept under control using selectable ride modes (Road/Rain), ASC, and ABS.
Unlike other motorcycles from BMW Motorrad, the F 900 R isn’t overloaded with unnecessary extras. Standard equipment includes LED lights, adjustable levers, a TFT display with BMW Connectivity, and a 12v socket.
For 2021, the F 900 R is available in three color options: Black Storm Metallic, San Marino Blue, and Mars Red Metallic, and BMW’s Motorsport Light White/Lupin Blue Metallic/Racing Red tricolor.
The 2021 BMW F 900 R starts at $8,995 USD / $10,350 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW F 900 R in one place.
- Price: $8,995 USD / $10,350 CAD
- High torque engine
- Dynamic ESA
- Gear Shift Assist Pro
- TFT dashboard with Connectivity.
- Engine: 895 cc water-cooled 4-stroke in-line two-cylinder engine
- Power: 99 HP
- Torque: 67 lbs-ft
- Wet Weight: 465 lbs (211 kg)
- Seat Height: 32 in (810 mm)
- Kawasaki Z900 ABS
- Triumph Street Triple R
- Yamaha MT-09
2021 BMW F 900 R Specifications
Engine | 895 cc water-cooled 4-stroke in-line two-cylinder engine |
Engine Power | 99 Hp |
Bore x Stroke | 86 mm x 77 mm |
Compression Ratio | 13.1 : 1 |
Fuel delivery | Electronic fuel injection |
Max Torque | 67 lb-ft at 6,500 rpm |
Clutch | Multiple-disc wet clutch (anti hopping), mechanically operated |
Transmission | Constant mesh 6-speed gearbox integrated in crankcase |
Drive | Endless O-ring chain with shock damping in rear wheel hub |
Suspension Front | Upside-down telescopic fork, Ø 43 mm |
Suspension Rear | Cast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable |
Brakes Front | |
Brakes Rear | Single disc brake, Ø 265 mm, single-piston floating caliper |
Tires Front | 120/70 ZR 17 |
Tires Rear | 180/55 ZR 17 |
Fuel Tank Capacity | 3.4 gal (13 L) |
Color | Hockenheim Silver Metallic / Racing Red |
Alternator | Permanent magnetic alternator 416 W (nominal power) |
Battery | 12 V / 12 Ah, maintenance-free |
Headlight | LED headlight |
Tail Light | LED indicators |
Overall Length | 84.2″ (2,140 mm) |
Overall Width | 32″ (815 mm) |
Overall Height | 44.4″ (1,130 mm) |
Wheelbase | 59.7″ (1,518 mm) |
Castor | 4.5″ (114.3 mm) |
Seat Height | 32″ (OE suspension lowering kit: 30.3″, OE low seat: 31.1″, OA high seat: 32.8″, OA comfort seat: 33″, OE extra high seat: 34″) |
Unladen weight, road ready, fully fueled | 465 lbs (211 kg) |
Warranty | |
Extension |
2021 BMW F 900 R Features
High-torque engine.
More torque, more riding enjoyment. Life can be that simple.
Agile chassis.
Sporty, intuitive, precise: is there any better feeling than being one with your machine?
Adaptive headlight.
One of a kind among the roadster class: steer into the light when turning into a curve.
Short exhaust.
Striking and crisp: for an expressive appearance.
Dynamic ESA.
Electronically adjustable suspension is a hard thing to find – but you’ll find it with us.
The 6.5“ TFT colour display and BMW Motorrad Connectivity. Connect your smartphone with your F 900 R via Bluetooth. The 6.5 inch TFT display will now show you all information relevant to your ride and also offers additional features like navigation, music and telephony.
Gear Shift Assist Pro.
You can switch gears without touching the clutch, keeping the tractive force smooth to give you more dynamism as well as more comfort as it keeps your clutch hand free.
Variety of seat heights.
Six seat heights from 30 to 34 inches: all riders will find the right height and secure footing for them.
2021 BMW F 900 R Photos
2021 BMW F 900 R Videos
BMW Official Websites
The post 2021 BMW F 900 R [Model Overview] appeared first on webBikeWorld.
