2020 Indian Challenger [Model Overview]
2020 Indian Challenger​
The 2020 Challenger is Indian’s entry into the muscle bagger arena. A 1,770 cc, liquid cooled 60 degree v-twin named the PowerPlus provides 122 HP and 128 lbs-ft of torque, making this the most powerful motorcycle in Indian’s bagger lineup.
With so much power, stopping power is important. That is why Indian worked with Brembo to create bespoke brakes for the model, with 4 piston dual calipers and discs up front, and 2 piston single caliper and disc out back. Suspension is also reworked, with an inverted fork up front and a hydraulically assisted monoshock at the rear to give the Challenger a sporting but comfortable ride.
The Challenger features standard ABS, cruise control, traction control, and Indian Ride Command 7 inch infotainment system with 100 Watts of power for the front fairing-mounted speakers.
The 2020 Indian Challenger starts at $21,999 US/$26,999 CDN.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Challenger in one place.
  • Price: $ 21,999 US/$26,999 CDN
    • Cruise control
    • ABS
    • Low Seat Height
Key Specs​
  • Engine type: 1770 cc, PowerPlus
  • Power: 128 ft-lb
  • Wet weight: 361 kg
  • Seat height: 26.5 in
Key Competitors​
2020 Indian Challenger Specifications​
ENGINE
Engine1770 cc, PowerPlus, liquid cooled 60 degree v-twin
Power128 ft-lb
Bore x Stroke4.251 in x 3.799 in (108 mm x 96.5 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel injection / 52 mm bore
ExhaustSplit Dual Exhaust w/ Resonator
DRIVETRAIN
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Primary DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontInverted Telescopic Fork
Suspension RearSingle Shock w/ Hyd adjust
Brakes FrontDual / 320mm Semi-Floating Rotor / 4 Piston Radial Caliper
Brakes RearSingle / 298mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires Rear
Metzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity6.0 gal (22.7 L
ColorTitanium Metallic
ELECTRICAL
Ignition
HeadlightLED
DIMENSIONS
Overall Length98.5 in (2500.7 mm)
Overall Width
39 in (990.2 mm)
Overall Height56.2 in (1428.5 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.4 in (137.3 mm)
Seat Height26.5 in (672 mm)
Wet Weight796 lb (361 kg)/831 lb (377 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2020 Indian Challenger Features​
FREE REIN TO DOMINATE
The all-new Indian Motorcycle PowerPlus, our biggest liquid-cooled engine, packs a best-in-class 122 horsepower and 128 ft-lbs of torque for reliable, exhilarating power.
CARVE CORNERS. ALL OF THEM.
Inverted front suspension, lightweight cast-aluminum frame, and hydraulically adjustable Fox® rear shock deliver curve-hugging handling and unyielding stability.
SUPREME TRACTION. SUPERIOR STOPPING POWER.
Race-spec radially-mounted Brembo® brakes provide superior stopping power, and performance touring Metzeler® Cruisetec® tires offer supreme traction.
Accordion Title
Waterproof saddlebags with over 18 gallons of storage space protect against all the elements.
CONTROLLED COMFORT. EVERY RIDE. EVERY DAY.
Class-leading wind protection and control at your fingertips with a power-adjustable windscreen on a chassis-mounted fairing.
FEATURES FOR GOING THE DISTANCE
Ride in comfort for longer with electronic cruise control, full LED lighting, a long-haul seat, ABS, and keyless ignition.
LIGHT THE WAY
Full LED lighting illuminates the road to ensure every ride is a safe one.
BEATS FOR THE STREETS
High-output speakers in the fairing deliver 100-watts of crystal-clear audio, while a dynamic equalizer automatically adjusts for road, wind and engine noise so you never miss a beat. Screen shows optional navigation upgraded with traffic and weather overlays.
A MODE FOR EVERY RIDE
Riders can customize the bike’s throttle mapping and traction control by selecting one of three ride modes—Rain, Standard, and Sport. The result: one motorcycle with three distinct performance personalities.
2020 Indian Challenger Photos​
2020 Indian Challenger Videos
The post 2020 Indian Challenger [Model Overview] appeared first on webBikeWorld.
